Cornering lights in fog lights
brian2.0TDiblue
Options: Sports pack - RNS-510, Alcantara seats,
Post by brian2.0TDiblue »
Hey, does anyone know if Scirocco's have the cornering feature where the fog lights turn on when going around bends, I've seen 2010 golds with it so I wonder why the scirocco doesn't have the feature.
Re: Cornering lights in fog lights
On cars with Xenons, the cornering light is in the main headlight cluster.
Cornering lights in fog lights is not standard but I believe can be activated with VCDS.
Roy_01
In: Sumatra
Post by Roy_01 »
Yes it can be selected in module 09 central electronics.
Coding, long coding byte 14 bit 7 for MY10 and onwards.
- cornering lights via front fogs active
brian2.0TDiblue
Oh right, wonder why VW didn't just enable it when they built it, thanks
Roy_01
In: Sumatra
Post by Roy_01 »
Thats a good question, there are a lot of functions that aren't activated by factory.
Maybe the more expensive the more they enable?
CleanDiesel
In: Indium Grey
Options: 184 TDI, Dynaudio sound system, adaptive suspenion, electronic differential lock, 90% tinted glass, cruise control, winter pack, reverse camera, fancy phone linking up stuff.
Post by CleanDiesel »
Because having fog lights on in built up areas or when it's not foggy is illegal I would guess is the reason.
Phil
In: Night Blue
Post by Phil »
CleanDiesel wrote:Because having fog lights on in built up areas or when it's not foggy is illegal I would guess is the reason.
I doubt it is the reason as its something which seat and others offer from factory in the UK already
Phil
Roy_01
In: Sumatra
Post by Roy_01 »
I added the coding to my vcds coding sheet.
http://www.sciroccocentral.co.uk/forum/ ... 36&t=21455" onclick="window.open(this.href);return false;
