Bixenon
Chris_r
Bixenon
Hi!finally I decide to change my oem headlights to bixenon so I bought a pair with ballast on!also I bought the bixenon adapters and I installed them to oem.i want to ask where to pin the yellow cables from the bixenon adapters to the bcm?
blower
Re: Bixenon
The yellow cables from the adapters will be for the high beam shutters. They go to pin 48 and 49 on the gold CECM (BCM) connector.
As you are probably aware you should also have the AFS HID leveller installed for them to be legal in the UK and pass an MOT - however not all MOT test centres check for it (or know how to check it). Having said that without the AFS module wired in you might find they are pointing in the wrong direction (too far down/up etc)
Chris_r
Re: Bixenon
Thanx for your help!is there a slot on the gold cecm with the mark 48-49?
blower
Re: Bixenon
Yep, once you remove the connectors shroud you will be able to see the pin numbers (they are on the back side or the face, i can't remember)
As seen in this pic:
courtesy of Bruno Prado
courtesy of Bruno Prado-
Chris_r
Re: Bixenon
thanks again!i will try it tomorrow!
Chris_r
Re: Bixenon
is there any tips how to take out the gold bcm??
