Deniz94
Posts: 86 Joined: Tue Sep 08, 2015 8:27 pm
Post
by Deniz94 » Sat Jan 16, 2016 12:26 pm
How the heck do you remove these? I tried 3 screwdrivers and none work...
Im trying to put them led lights on...
Posts: 5036 Joined: Sat Aug 07, 2010 2:31 pm
Post
by Cuprabob » Sat Jan 16, 2016 12:36 pm
You need a Torx driver or bit that's the correct size. A standard Philips or Posidrive screwdriver won't do.
The majority of the screws on VWs are Torx these days so probably worth investing in a set.
blower
Posts: 466 Joined: Tue Oct 06, 2015 7:01 pm
Post
by blower » Sat Jan 16, 2016 10:43 pm
They will be T30 Torx bolts.
As above, many torx screws on a VW, along with hex heads (allen), and spline (tripple square).
Also as the car is german, if you start doing work on it you will find they use unusual sized heads, usually requiring a hex bit, spanner or socket that you don't find in your socket set unless it has every single size possible!
