Interior lights fault
Camfifteen
Hi guys, hope you can help. I've got a 10 plate 2.0 tdi, the glovebox, boot, map and interior lights have stopped working. Can't seem to find fuse list. I know there's 3 fuse boxes. Foot well lights and red interior lights are working. Any help appreciated
Re: Interior lights fault
http://www.sciroccocentral.co.uk/forum/ ... =25&t=7403" onclick="window.open(this.href);return false;
- Roy_01
Check fuse 24, did you short it to ground somewhere?
I had a problem with the led in the glovebox before...
Camfifteen
Tried fuse 24 in engine bay and fuse 15 in the drivers side of dash no joy still, I didn't short it. Also the visor lights aren't working
greg7728
Have u checked for a wiring diagram for the roc? Sounds like these things either share a common fuse or a common earth. Find where the earth point is and check that, that'd be where I would be looking if u have ruled out a fuse issue.
- Roy_01
And an autoscan with vcds will also be very usefull for this problems maybe you can make one?
