Water leaking?
JohnsonAsco
Options: Gloss Black 19" Lugano Alloys, K&N Induction Kit, Carbon Interior Trim, T5 Mod R Line Grill, Dectane Tail Lights,
Water leaking?
Post by JohnsonAsco »
I just noticed this evening when parked up with the car running speaking to somebody water leaking from underneath and first I didn't think it was mine but I moved the car and it made another damp patch, it seems to be coming from say between the middle of the seats but obviously from underneath the car on the outside, it's going in for a service tomorrow so I'll mention it to the garage I'm going. But just wondering if anybody has a heads up of what it is? Not coming from the engine, all fluids ok with no loss, temp same as usual. Just leaks when car is running don't think it does when not on. Cheers. Pat
Parsx
Options: Mods:
Black VW Badges and others removed.
APR Stage 1
Red Pinstripe
HT Autos Splitter (Now dead)
ITG induction kit
H&R Springs
Re: Water leaking?
Post by Parsx »
Did you have your air con on? Had this in other cars when I've had it on for a bit and some condensate drips out when stopped.
JohnsonAsco
Re: Water leaking?
Parsx wrote:Did you have your air con on? Had this in other cars when I've had it on for a bit and some condensate drips out when stopped.
Yeah mate I have my air con on near enough all the time just so it's running. Is that what it is then?
Parsx
Options: Mods:
APR Stage 1
Red Pinstripe
ITG induction kit
H&R Springs
Re: Water leaking?
Post by Parsx »
Not 100% and someone may correct me but I think it is from a drain from the a/c unit. The evaporator or condenser makes water when cooling the air and then dumps it when stopped. Happens all the time in the hi luxs I drive at work.
JohnsonAsco
Re: Water leaking?
The person who I was with at the time said about the air con as well same thing as what you said. So see what anybody else says. Thanks though appreciate it.
Paddy_R
Re: Water leaking?
Post by Paddy_R »
It will nearly certainly be the air con. Should be good clean water as everything else in your car will have something added ie coolant, screen wash etc.
selleym
Options: Mirror Pack
Mods:
Bonnet Struts
Metal Pedals
Re: Water leaking?
Post by selleym »
Paddy_R wrote:It will nearly certainly be the air con. Should be good clean water as everything else in your car will have something added ie coolant, screen wash etc.
^^ This
JohnsonAsco
Re: Water leaking?
Yeah must be the air con :-) cheersssssss ladssss
WoeisJick
In: Indium Grey
Options: Default Volkswagen Set Up
Muffler Delete
Re: Water leaking?
Post by WoeisJick »
If its dripping outside of the car from underneath then that shouldnt be a problem, all cars do that when leave it running with the aircond on.
Its only a problem if the water drips from the inside and wets your interiors, floor mats etc.
I had that problem just about 2 weeks in after purchasing the car, the drain tip wasnt pointing out as it shud've been which totally wet my car on the inside, brought it back to the dealer and had them fixed it, as the wet also screwed my airbag ecu.
I'm guessing it was a faulty from the factory or it was just fine when they inspected it.
