Spare Tyre Pressure
selleym
Options: Mirror Pack
Mods:
Bonnet Struts
Metal Pedals
Spare Tyre Pressure
Post by selleym »
Ok.
Had a front puncture so have put the space saver spare on for now. Getting repaired. :cry:
The outside of the tyre states Inflate to 60psi
But the book says for a spare inflate to the max psi rated on the fuel cap. Which is 39psi for front 45psi rear.
Which one...?
therealtimmsy
Re: Spare Tyre Pressure
Post by therealtimmsy »
id go fuel cap. 60 psi seems excessive. just my guess mate.
chelspeed
Options: Sold it!
Post by chelspeed »
Does the fuel cap specifically say space saver pressure? I suspect the reference to the spare in the manual is for a full size spare but if so 45psi seems high for a full size spare.
The space saver is very thin so has a much smaller square inch on the road. To get the same load bearing you need a much higher pressure to take the same load. The pressure is in psi, pounds per square inch, so for the same load (pounds) you need more psi as there's less square inches.
If the spare says 60 psi you should use 60 psi.
selleym
Mods:
Bonnet Struts
Metal Pedals
Post by selleym »
Cheers guys.
I am using 60psi just wanted to double check.
Shame a full size spare won't fit in the Rocco.
Stupid space saver is tiny the whole car leans loads to that wheel
therealtimmsy
im thinking of taking my spare out so i can do an amp build in there. Just keep a can of tyre weld in the boot lol
selleym
Mods:
Bonnet Struts
Metal Pedals
Post by selleym »
Hey timmsy the tyre weld isnt working for some reason...
:clap:
therealtimmsy
HAHAHA nice one ;) just fill it with leaves and grass itll be fine!
