Bi-xenon retrofit to my09 scirocco - red mfd
- V5pdt
Has any one done this retrofit?
Is there a fitting guide as I've bought the kit to fit but realised its really meant for a my10 onwards with white mfd.
As my09 rocs came with xenons I presume it can still be done!
Any help welcome!
Any help welcome!
metaljay
Re: Bi-xenon retrofit to my09 scirocco - red mfd
My guide I'm pretty sure applies to red dashes as well...only one way to find out
- V5pdt
Yep have had a scoot through your guide but modules are different so wondered where to connect cables onto!
Cheers metaljay
Cheers metaljay
Gazzagood
Im doing this at the moment and i need to change my BCM module for a "highline" one and have it coded in with vagcom. I have module and vagcom on the way. I have the lights and adapters already so I will let you know how I get on.
I have a 58 2.0 TSI with red mfd
- V5pdt
Thanks for that gazzagood....don't suppose you have a part number for the bcm module?
I have vagcom so not a problem....
Gazzagood
Well my vagcom arrived and it turns out I dont need a new bcm as I have the correcto one, even though the ebay seller of the adapter tried selling it to me, luckily I backed out of the bcm last minute until vagcom come!V5pdt wrote:Thanks for that gazzagood....don't suppose you have a part number for the bcm module?
On vagcom my vag part number of central electrics module (09) is 3C8 937 049 E
You can check yours against this list to see if you need a new one - http://golfgti.dk/vw-seat-skoda-central ... dule-cecm/" onclick="window.open(this.href);return false; yours must be highend to be ok. If its medium then its no good.
From what I have worked out, if your car has foglights then you have the highend BCM.
Gazzagood
All done in my rocco 58 plate with red highline instrument cluster. No need for new bcm module, just needed to change coding on vagcom. Everything working perfectly, need new indicator bulbs for when I do my R front bumper next weekend
Will get better pictures once its a bit darker.
- V5pdt
Thanks very much for the info....
As I have cornering fogs enabled I must have the highend module.
Can you tell me what pins you used and if you fitted an auto levelling switch?
Phil
Phil
Gazzagood
I assume you do thenV5pdt wrote:Thanks very much for the info....
Phil
No auto levelling but I may look into that in the future as it can be done
Might cause a problem come MOT time, as auto-levelling and washers are a legal requirement with XenonsGazzagood wrote:V5pdt wrote:
Might cause a problem come MOT time, as auto-levelling and washers are a legal requirement with XenonsV5pdt wrote:
Gazzagood
I wont post that on forums, will be ok. I plan on putting auto levelling in next I have just saved the links for the bits I need to buyCuprabob wrote:Might cause a problem come MOT time, as auto-levelling and washers are a legal requirement with XenonsV5pdt wrote:
And I have scirocco R front bumper currently in the body shop and it has headlight washers
trucas11
Hi do you have coding? i need for my scirocco
