Hi guys,
I was wondering if anyone could help me with a couple of quick questions from a new owner. Thankyou. Apologies if I'm meant to post these in separate sections, let me know.
1) I've managed to connect my old ipod (wide thin 30 pin connector type) to the AMI music system with use of a cable i was given with the car. I then tried my new ipod with the lighting connector lead into a USB female - AMI lead i was also given but the car doesn't recognise the device. I assume this is because the ipod is about three years younger than the car - is there any way to get this to work through the AMI music system?
2) I currently don't have my user manual at my flat. On the MFD there are values for time, mpg and distance with either a small 1 or a 2 beside it. What do these mean? I'm assuming one is continuous and one resets itself or something, but what do these actually mean?
3) When i press the passenger window to close completely by itself it sometimes gets half way and then goes back down again as if something is stuck in the window. Am i just being stupid?
4) Looking at lowering the car - if either Eibach or H&R springs are used, should there be any problems with fitting small spacers too with standard 18" interlagos wheels? I'm assuming not, but i'm very new to this owning a nice car business.
Any help is much appreciated,
Thanks,
Simon
Questions from an amateur.
luc1989
Re: Questions from an amateur.
I've no idea how to help with your first question but regarding the MFD nr one resets itself after you've swiched off the engine for a while and nr 2 shows you long term distance and mpg.
Regarding the window that does not sound normal to me,my R has never done that from new.
Hope that helps a bit
Regards
Lucian
Regards
Lucian
Right dunno abt the first question.
As for the window mine does it sometimes. What you do is short clicks until the window is up and then hope it wont do it for some time after
As for the trip 1&2, the number one resets every journey whilst number two keeps averaging until you reset the trip calc manually or every 8-9 k miles when it resets on its own
Simon92
Magic, thanks for all the help. With the music I think I might just have to assume that a new lighting connector Ipod is too modern. The 1s and 2s on the trip computer makes sense - sounds like it was what I assumed. Thanks!
skippy
- Moderator
Yes - the number 1 average trip reading resets after 2 hours of inactivity.
