My mpg reading is fluctuating like crazy going up and down contantly
Done a factory reset but not worked
Any ideas please
Mpg readings going mad
- selleym
Re: Mpg readings going mad
Got it on the Real time MPG screen?
Will go up to 200mpg
- Kev
- Administrator
Yeah my guess is the real time one as well.
The average one has a circle with a line through it next to the value to denote an average value. The real time one goes up and down and you press the accelerator. If you lift off completely it goes to ---mpg
alanr
- I drive a: R-Line
Yes mate both not working
alanr
- I drive a: R-Line
Just to add been on a three hour drive and up and down
Constantly and the average mph didn't move off
48.3 mpg
48.3 mpg
- AxG
You need to press and hold 'ok' until the reading flashes and then it will change.
- Kev
- Administrator
The other thing to check is whether there's a little 1 or 2 in the top corner.
1 is the current values, 2 is the averages since the car was made (or at least the last 10k miles or so).
mrhirst
Btw you can reset the 2nd set of averages, distance, speed etc by pressing and holding the OK button on wheel. 1 seems to reset after a few hours of the engine being off
