I have a MY09 Scirocco with the Mk6 dash and OEM xenons with cornering lights (seperate bulbs in headlilght cluster).
I have been able to code it so when I go into reverse, both the cornering lights come on however I would like it so I can have the fog lights and/or cornering lights come on when I activate full beam (with xenon shutter).
I've done some searching but can't quite find what I'm looking for, any help?
Coding cornering / fog lights to work with Xenon shutter
- Roy_01
Re: Coding cornering / fog lights to work with Xenon shutter
Byte 14 bit 2 in module 09 uncheck fog lights inactive with high beams active.
Don't know if this bit is present on a MY09.
xjay1337
Thanks for the info. I will take a lookRoy_01 wrote:Byte 14 bit 2 in module 09 uncheck fog lights inactive with high beams active.
Although I don't have foglights now with the R bumper...
- Roy_01
Ok then it will not make a difference, you can only code the foglights at the same time with high beam.
Maybe also possible for the cornering lights but i think you will need vag can pro for this.
Redleh
Hi!
I have a Golf 7, and I have enabled the fog lights to work at the same time as the high beam, with out using the switch lights to turn the fog lights on.
Is it possible to do the same with my Rocco MY10 with Xenon, to turn on the fog lights when I turn on the high beam?
"Byte 14 bit 2 in module 09 uncheck fog lights inactive with high beams active."
I believe this option is for when I have the fog light are on on the switch light, that prevent from the fog light to switch off when high beam are on.
