Hi!
Anyone know what this means?
MID: $02 TID: $66
02 Bank 1 Sensor 2
65520 way to hi it says!!
Checked the car for codes and this showed up!
Mike
obd check
Re: obd check
Looks as though one of the Lambda sensors is detecting too rich a value from the exhaust gas.
- hoganb
Re: obd check
Thanks! Anything I should do about it?
Harmfull to the engine?
Could it be related to revo stage 1??
Scirocco mk III
Re: obd check
I would clear it and see if it comes back.
I know Revo can run rich, but if that was the case the sensor on the other bank would also be logging high values.
If the car runs OK and EML doesn't come on I wouldn't worry too much about it.
- hoganb
Re: obd check
"If the car rubs IJ and EML doesn't come on I wouldn't worry too much about it.[/quote] "
What does IJ and EML mean?
The code is still there!
Scirocco mk III
Re: obd check
"hoganb wrote:"If the car rubs IJ and EML doesn't come on I wouldn't worry too much about it.
The code is still there![/quote]
It was a typo, what I meant to say was "runs OK" and EML is Engine Management Light
- hoganb
Re: obd check
Ah ok. Thanks!
Yes, runs great as it has done since new!
Knock on wood!
Knock on wood!
Scirocco mk III
