Hi all,
Only had my rocco a day and I have a warning light on. Looks like this (!) The manuel says it's brake fluid level too low, or fault in the brake system.
This light came on about two mins after I filled the car up for the first time.
Is it serious? I'm a little worried as I have only had the car less than a day.
Has anyone got any ideas?
Many thanks,
Ash
Warning light
BishBosh84
Re: Warning light
I would suggest anything to do with brakes is serious. If you bought it from a trader / dealer take it back to them and have them fix it. If you bought privately, then bad luck and get a local dealer / indy check it out.
If the warning light is yellow then it's safe to drive with caution. If it's red then I woulfn't risk it.
You can check the brake fluid level but it shouldn't drop by much due to brake wear
BishBosh84
Re: Warning light
Thanks for the reply, however upon second look it's flashed up tyre pressure change on one or more wheels, so relieved to say the least haha.
I've got 18' interlagos wheels, does anyone else have this trouble? The tyres seem fine, however I am only really used to my 15' on my old mk4 Golf. This is all abut new to me.
Re: Warning light
Don't know how you could mix up those symbols, but that's good news:-)
The tyre pressure monitor works off the ABS wheel sensors and doesn't measure actual pressure. It detects a change in rolling radius of the wheel. When the tyre pressures are adjusted or a wheel or wheels have been off the datum for the system needs reset. You reset by pressingamd holding the reset button located.either in the top right of the glovebox or in front of the gearstick, depending on the year of the car. When it's reset ypu hear a beep and the light goes out.
It's all explained in the manual.
You do get the odd false alert as it's quite sensitive.
BishBosh84
Re: Warning light
Thanks bob, much appreciated.
I've had it less than 24hrs so I just panicked haha
Cheers again.
Cheers again.
matt_j_smith
- In: Night Blue
Re: Warning light
I have three new tyres and one slightly older.. With a boot load of stuff (and perhaps a 'large' mate) it will trigger it! Very sensitive...very handy!
Sent from my RM-914_eu_euro1_327 using Tapatalk
robb
Re: Warning light
haha i also crapped myself when this light came on in my dads polo, i thought it was a coolant issue for some reason until i rang him, fair to say i got some stick off him for being an idiot !
