P Zeros
JohnsonAsco
- I drive a: R-Line
P Zeros
Anybody got a link for 19 p zeros.... New ones. Only need one just hit a pot hole and it's took a chunk out.. Plus a chunk off my alloy.. Lovely stuff!
Re: P Zeros
VW OEM P Zero is (K1) suffix. Here is a link to.the exact tyre on Camskill. Not a bad price too.
http://www.camskill.co.uk/m55b0s24p1013 ... se%3A_72dB" onclick="window.open(this.href);return false;
JohnsonAsco
- I drive a: R-Line
Re: P Zeros
Thanks mate, have you ordered off here? Or know anybody that has?Cuprabob wrote:VW OEM P Zero is (K1) suffix. Here is a link to.the exact tyre on Camskill. Not a bad price too.
Re: P Zeros
Yes, I bought a pair of those very tyres last year. No complaints and tbey were delivered within a couple of days.
A lot.of people use.Camskill for performance tyres.
JohnsonAsco
- I drive a: R-Line
Re: P Zeros
Cool thank you. I'm proper fussy when it comes to stuff like that, have to have all the same original tyres and stuff, it's rather annoying sometimes! I'm not sure if I'm gonna change it yet though it's made a little rip but I drove home on it and it seems fine but i might change it to be safe.
Re: P Zeros
I would buy one and have it ready to.swap out if need be. Also, that's a cracking price, not seen them as low as that before.
JohnsonAsco
- I drive a: R-Line
Re: P Zeros
Why do you think they are so low? You sure they are legit tyres like the same ones on my one now, yeah ill probably order one on Thursday pay day! I'm surprised it didn't burst to be honest it proper whacked it!
Re: P Zeros
Yes, they are legit tyres. Camskill is a reputable company. Tyres is something I would never risk or compromise with. Tyre prices do vary over period. I tend to buy a pair when the price is low and keep them just incase something happens. Sod's law is when you need.one the price will be at the highest or worse still you need to buy one from Kwik-Fit.
- Andy Rocc
Re: P Zeros
Try these too http://lovetyres.com/" onclick="window.open(this.href);return false;
JohnsonAsco
- I drive a: R-Line
Re: P Zeros
I've ordered off Asda now £141 for delivery and for them to be fitted, I ordered the correct tyre but there was a few different names like "Rosso" and "GT" I ordered the Rosso one... Is that right?
Re: P Zeros
Sadly no, the P Zero Rosso is a different tyre with different compound and pattern.JohnsonAsco wrote:I've ordered off Asda now £141 for delivery and for them to be fitted, I ordered the correct tyre but there was a few different names like "Rosso" and "GT" I ordered the Rosso one... Is that right?
The OEM tyre fitted from the factory is a standard P Zero with the (K1) suffix, exactly the tyre in my link. There are a number of P Zeros with different designations for different manufacturers. On too of that there are also different variants of P Zero such as Rosso, Corsa and Nero.
The tyre you have ordered will do the job obviously, it will just not match the other 3.
Just have a look at the link below and you will see the difference in tread pattern between P Zero and P Zero Rosso.
http://www.camskill.co.uk/m55b0s24p0/Ca ... _235_35R19" onclick="window.open(this.href);return false;
I can appreciate it can be confusing.
JohnsonAsco
- I drive a: R-Line
Re: P Zeros
http://www.asdatyres.co.uk/select-tyres-and-savings" onclick="window.open(this.href);return false;
If you click on perelli link, is the OEM ones of there?
Re: P Zeros
I can't get the Asda site to work on my phone. I think from my previous posts and links it's quite clear what the VW OEM P.Zero tyre is. It's a standard P Zero with.no name after it and the suffix (K1).
JohnsonAsco
- I drive a: R-Line
Re: P Zeros
I've ordered the link you sent me mate, I ordered the asda one but you don't have to pay till it reaches the fitting centre so I will just not turn up to the appointment, when the one from camskill comes I'm gonna have to get it fitted, how much should I be paying? Know any firms that is should go to? Easiest will be kwik-fit probably.
Re: P Zeros
Expect to pay around £15 for fitting and balance
Some of the big chains like Kwik-Fit are a bit funny about fitting tyres tjey haven't supplied. I use my local dealer but your local indie tyre fitting place should oblige.
