Rain sensor standard?
mhopley
I am looking to buy a scirocco at the moment and I was just wondering if any one knows if the rain sensor is standard in a 2009/2010 car?
Mark
Mark
Just Bought - White Scirocco with DSG and leather.
skippy
- Moderator
Re: Rain sensor standard?
Hi Mark,
Yes - my 2009 model certainly came with a rain sensor as standard.
mhopley
Thanks Skippy.
I assume that auto lights are standard as well.
skippy
- Moderator
No worries, indeed auto lights are standard.
The Rocoppedia may help you here: http://www.sciroccocentral.co.uk/roccop ... el_Changes" onclick="window.open(this.href);return false;
Although fitted with autolights, on cars with standard halogen lights, the function is redundant as the headlights are on dipped beam all the time in lieu of DRLs. Can be disabled using VCDS so auto lights work as intended.mhopley wrote:Thanks Skippy.
Function.works fine on cars with Xenons.
More fom me on this (long running) subject at the end of this thread:
http://www.sciroccocentral.co.uk/forum/ ... 75#p134375" onclick="window.open(this.href);return false;
skippy
- Moderator
Don't quite understand this, my auto lights do function as auto lights, when light levels go low, like driving into my garage, the main headlights do come on . Normally it is just DRL's (dipped beam).Cuprabob wrote:Although fitted with autolights, on cars with standard halogen lights, the function is redundant as the headlights are on dipped beam all the time in lieu of DRLs. Can be disabled using VCDS so auto lights work as intended.mhopley wrote:Thanks Skippy.
- Ozmosis
If your car has Xenons then the DRL's are different to the main headlights. If you do not have Xenons, then the main headlights (dipped) ARE the DRL's.
- Andy Rocc
Is there anyone around the Manchester area that can disable the dipped beam as the DRL and just leave the side lights as DRLs? With this done would the dipped beam in auto position work as it starts to go dark?
Thanks.
Thanks.
robb
i couldn't find anyone in manc mate, ended up going awesome, altho shak on scirocco net is offering to do it cheaper then them down bolton
- Andy Rocc
So now with your switch in the auto position your dipped beam will come on when it goes dark?robb wrote:i couldn't find anyone in manc mate, ended up going awesome, altho shak on scirocco net is offering to do it cheaper then them down bolton
Yes - once the 'stuck on all the time' headlight setting is deactivated the AUto function will work and go off and on as dalylight levels.
