So, surprise surprise i have a bluetooth issue.
well, a couple.
Firstly, how do i change the bluetooth name of the car?? mine is some German name i can't even pronounce!
Secondly, sometimes, when connected to bluetooth, the car decides it wants to cut out all the calls after half a ring. whats that about?! whether its incomming or outgoing. The only way to fix it is to switch the car on and off. I have tried switching the unit off, disconnecting and reconnecting....nothing!
any ideas?
thanks
Bluetooth Issue - i know...
- Minnu
Rising Blue Scirocco Sat Nav/Heated Leathers/Park Sensors/Pan Roof/19" Lugano Wheels
dstill
Re: Bluetooth Issue - i know...
You should be able to delete the user name you don't want through the MFD, however I have only done this on mine which has the highline MFD so not sure if its possible on low line MFD's, not sure what yours is mate.
Cant help with the disconnection issue, sorry.
- Minnu
thanks, no i can't change it in the MF-ing D! its so frustrating! haha
