Just changed headlights to the Mtec H7 55w Super Whites. Was surprisingly easy, only took about 5 minutes, must have small hands. Also replaced sidelight and number plate W5W bulbs for the 8 LED SMD 5050's from Fizzmo off Ebay as recommended by someone else off here. Will get a picture up later when its dark. Well happy compared to the original yellow stock bulbs.
A tip for you on the LED's if like me you have had problems with them corroding and failing. Smear all metal parts with Vaseline before you fit them and it should stop the moisture getting to them for a good while.
