Phone cradles
bitmadmax
Phone cradles
Post by bitmadmax »
Hi All,
Has anyone got any experience with phone cradles? I basically want to be able to mount my android phone so I can use it as sat nav/power it at the same time (I only have RCD-510)
I was looking at the Bury system 8/9 stuff - I believe these were the same sort of thing VW used to fit as an option but was just rebadged
Does anyone know if there are any pre-drilled holes for the mount? Pictures on the net seem to show the mount fitted towards the lower left of radio volume button somewhere behind the trim.
Cheers.
Golf 7R
Gone: Scirocco R
VCDS available
trix
Ordered 23rd June 09
Build week 41
Handover 17th Oct 09
Missing RW1
Re: Phone cradles
Post by trix »
I mount like this http://www.sciroccocentral.co.uk/forum/ ... ick#p52111" onclick="window.open(this.href);return false; when I use it as a satnav, which avoids having any obvious mounts or marks :)
drfez
I drive a: 1.4 TSI 122/125
In: Indium Grey
Options: Parking Sensors
Chrome tips
Re: Phone cradles
Post by drfez »
I was looking for something that wouldn't leave suction marks etc too. I came across tetrax x way - attaches to the airvent. Only downside is you need to attach a magnet to your phone cover and the ££ but definitely worth it
dimexi
VAGCOM Mods:
DRL/PRL off
Needle sweep
XDS on
Big mph speedo
Alarm beep
Windows close via rain sensor
Other Mods:
Metal Pedals
Self installed Cruise Control
RNS510
Stage 1 Bluefin
Re: Phone cradles
Post by dimexi »
The bury system doesn't require nod drilled holes. The used some sort of double sided adhesive to hole it on to the dash.
Never seen it sold before though, maybe at electrical stores.
maq
Options: 19" Black Luganos/Style Pack, Vienna Leather, Parking Sensor, RNS-510 + VIM patch, VW Bluetooth & A2DP, Cruise Control, Aluminium Pedals
Re: Phone cradles
Post by maq »
I spent ages looking for a good cradle for my iPhone. I ended up finding this, which in my mind isn't very intrusive at all and requires no sticking, mounting or anything. I like it so much I've actually put a hold on my covered cup holder install. Not eye level for sat nav but similar to the height of Trix's mount. I have an RNS510 but when I use my phone as sat nav in my other car, I rarely need to look at the screen anyway.
I think they come up pretty cheap on eBay too
bitmadmax
Re: Phone cradles
Post by bitmadmax »
maq wrote:...
That's an interesting one, thanks.. :)
Golf 7R
Gone: Scirocco R
VCDS available
Rob
In: Salsa Red
Options: Scirocco's gone!
Re: Phone cradles
Post by Rob »
I use one of those dash mats that anything sticks to it, got it off eBay for a pound, cut it down so its slightly larger than my phone and have it covering the rev counter. When your not needing the holder it stores nicely in the glove box.
MartyRocco
Options: Cruise Control
Rear Parking Sensors
Factory Debadge
Re: Phone cradles
Post by MartyRocco »
I've just added a Brodit centre mount from DSL Developments http://www.dsldevelopments.com/brodit/f ... l=Scirocco for my SatNav as I find the window mounts place it too far away to reach comfortably. It took a little while to arrive as they had to order in from the manufacturer, but I'm pleased with it so far. It may look a little intrusive without the device attached, but I've been wondering whether I could fashion a blanking plate to cover the screw holes....anyone know anyone with a 3d printer?!
TriGGER
Options: Parking Sensors, Leather Interior
Re: Phone cradles
Post by TriGGER »
http://www.carphonewarehouse.com/phone- ... ON-HOLD-V2" onclick="window.open(this.href);return false;
Get the above, I've been using it for many years. It only breaks when you get a turnip otherthan yourself that doesn't know how to release the phone and then breaks the damn thing. I've had about 3 in the space of 5 years. Fit's all phones, will always stick to the windscreen without dropping randomly unless poorly sucked to the windscreen during installation. It's really really really good.
Gilez
Options: Folding mirrors, luxury mats, Black leather interior, DAB RCD510 Radio, Sill Protectors
LED side, interior, number plate, puddle and footwell lights.
DRL coded off, so side lights only. Beep for alarm set/unset coded on.
Build Week 5 2010
10.02.10 - on the boat to the UK
20.02.10 - Took delivery
Re: Phone cradles
Post by Gilez »
I just sit mine in the cup holder nearest the gear stick, and use a USB adaptor lead plugged into the armrest with a short Nokia USB-micro USB lead. It fits a treat and find it easy to glance down to the screen if needs be. Also works well to use the speakerphone when driving, as the sound from the speaker in the back of my phone "bounces" back out of the cup-holder.
I have also used a cigarette lighter USB adaptor and just sat the phone sideways in the space under the dashboard in front of the gear stick, but isn't as easy.
