Hey. I have a 2010 Scirocco 2.0 TFSI with manual air conditioning. Is it possible to get the air conditioning to automatic?
What about the seat heater, it seems to be lacking? Is there any way to work or is it an expensive solution to get to work?
Xenon light, whether the inability to replace the so-called halogens. like the original?
Climatronic & seat heaters & xenon light
b0rk
Re: Climatronic & seat heaters & xenon light
If you don't have climatronic retro fitting is not economical the system is much more than just the console panel. To get heated seats you'll need to the change the seats either with new seats or used seats from the likes of ebay.
- bianco
Heated seats can be had by removing the cloth, and installing the OEM heating elements. Wirering it might be a bit more tricky.
