Water laying in the petrol filler sump
- buster
Re: Water laying in the petrol filler sump
I just push some bendy wire through the small hole a short distance, ie. 1cm. What is behind is a wider rubber tube extension of the rubber surround to the tank filler pipe. As long as the wire will bend easily, it wont do much harm.
Its just a small plastic plug seated in the rubber which has a central hole in it. The hole is about 5mm deep and then goes into a much wider tube, the diameter of the plastic plug.
- buster
cheers RW1 for getting back so quick tried it but my bit of bendy wire was to short at about 7 inches, ill have to try and sort out some a bit longer just may be frozen at the moment though. regards buster
The tube beyond the plug you can see in the filler cap/rubber comes out in the rear wheel arch wall, forward of the rear righthand shock and slightly more inboard. Its a clear tube at that point.
You will need to take off the wheel & tyre to really get at it. And I seem to remember it runs inbetween the fibre wheel arch liner and the body work (hidden) when above the tyre area.
Like you say, could be plugged with ice but if it is, there is an underlying blockage that has stopped it draining (dirt or the clear tube is pinched). Water should flush straight out leaving the tube dry (and therefore not freezing). Mine makes a sucking noise in the small plastic plug hole in the filler area as it completes its drainage.
Must admit I have the same problem, so thanks for that RW1
- buster
RW1
from what you say i think ill get on to the dealer when it warms up a bit, as this has been like this from new, as you say may be kinked or another fault. its a motability car so i am restricted to what i can do myself. even removing a wheel. means a trip to quick fit. so thank you for being so helpful, and steering me in the right direction. regards buster
Yes realised your circumstances but not precisely, so not sure what you could do yourself. If since new, then it suggests a kink. Its only silicon tubing like in B&Q, so can easily collapse if not fitted correctly
This is where it comes out, clipped to the petrol filler downpipe into the petrol tank (red arrow)
- a4gee
Have you stripped your car and rebuilt it?
You know a lot
Hose / pressure washer. Give it a blast down the hole.
- silver130
My 1st Scirocco did this regularly. I just used to pudge around the bung hole a bit with my finger and hey presto the bit of crap that had blocked it would shift and all the water would drain away. Not had the problem once on my new one though
IF IT'S NOT BROKEN
I'VE NOT TOUCHED IT YET !!
Would it be obvious if i had this problem???? i.e would i notice anything wrong with the way my car works??? i dont really understand what you guys are talking about tbh, but would want to see if i have the same problem!
You would have a small pool of water below the filler pipe inside the fuel flap area if its blocked after washing the Scirocco (or when it rains).Babajang wrote:Would it be obvious if i had this problem???? i.e would i notice anything wrong with the way my car works??? i dont really understand what you guys are talking about tbh, but would want to see if i have the same problem!
I Do have a puddle in there!!!!! time to try and do what you lot have been doing!
- Ryy
I ain't proud of this, but I have no idea what is going on here. It's people like me that keep dealers in business. lol.
Shame on you Ryy.
Just don't make the mistake of trying to put the fuel pump nozzle down it. Thats the big one above it under the twist off cap.
- Ryy
lol. I ain't that thick. I've never even seen that though. My cap doesn't get full of water, so hopefully no issue!
I give mine a jet wash every time i clean the car dunno if its makes a difference!
- buster
Useful thanks to the late Chris!
I got odd looks when I had to scoop out all the water at the pump.
Get some Mr Muscle down it
Golf 7R
Gone: Scirocco R
VCDS available
Gone: Scirocco R
VCDS available
