Hi All,
I've seen at the following link...
http://www.my-gti.com/1319/volkswagen-r ... ssignments" onclick="window.open(this.href);return false;
...that there are available the following signals on rear connector of RCD310
AUX output, audio, right , AUX output, common signal earth and AUX output, audio, left
someone knows if it's possible to use them as PRE-OUT to connect an external amplifier?
Thanks and Regards
Don Porfirio
RCD310 Aux Output
Don Porfirio
Re: RCD310 Aux Output
Hey Don,
I'm trying to figure out the same, did you get any info on the aux o/p. Please do share if you get any info
Thanks & Regards.
Thanks & Regards.
