Hello fellow vw drivers.
I have just acquired a 2009 2.0L TDI (140) in blue with 20.000 miles on the clock. It looks great and drives well. I must say I am disappointed with the brakes though, they are very sharp at low speed and fade when braking from high speed. I have just spent some of my hard earned money on this vehicle and wondered if there is a cost effective fix for this problem. I only intend to use the car for some occasional enthusiastic driving. Any suggestions would be welcome.
Thanks in advance
Richard
Brakes
fun meter
Re: Brakes
Its the pads, they are crap. I replaced mine for Mintex 1144's, which are about the same initial bite, higher speed braking is a lot better and once warm are more resistant to fade, better on track and good for road. Only major problem is, they really squeal a lot at low speeds. Mine stopped making noise when 50%+ worn. Im tempted to try something different, but its hard to find others who have.
Re: Brakes
Thanks for your reply fun meter. Sounds like you wouldn't go for the 1144"s again and they are a pretty penny. Hope fully other members will leave some feedback on other brake pads.
Rich
Rich
- Gary_Monkey
Re: Brakes
I find the breaks exactly as you do. Very sharp at low speeds and lots of fade when breaking from 50+
Gaz
Gaz
Car Deliverd :-) 10 Nov 2009
fun meter
Re: Brakes
No worries. 1144s are good, but it depends if you can put up with the noise. I paid about £140 for a set (I think).hardwick wrote:Thanks for your reply fun meter. Sounds like you wouldn't go for the 1144"s again and they are a pretty penny. Hope fully other members will leave some feedback on other brake pads.
Rich
I dont do much mileage for work, but I do a few track days so I could justify the noise.
b0rk
Re: Brakes
Pretty well any decent upgraded pad will be £100+ a set. Your basic upgrade pad choices would be mintex 1144's, mintex 1155's, ferodo FDS, ferodo DS2500's, Pagid RS's or CL.
Re: Brakes
Thanks for your replies, I've spotted some pagid brake pads (front) at £37.80 from Euro car parts. Cheap enough to give them a whirl me thinks.
b0rk
Re: Brakes
There the same as the OEM pads... pagid are the OEM manufacturer for VAG cars.
Re: Brakes
thanks bOrk for the info, I would have been a bit miffed if I got some pagid pads and they were exactly the same.
