Facelift xenon retrofit (AFS, dyn. & static cornering)
mrsavvy90
Options: Leather seats , Xenon Headlights, Reverse camera, Upgraded PREMIUM Audio, RNS 510 SATNAV rear parking sensors
Re: Facelift xenon retrofit (AFS, dyn. & static cornering)
Post by mrsavvy90 »
ROY 01 IS THERE ANY CHANCE YOU CAN HELP ME ? you are very good ! thank you for the guide ,
so my facelift xenon is now almost all workings , Projectors led strip , led square , etc all working
i made afs adapter and it works ! projectors move up and down which is good but not left & right
I'm trying to code the afs but no luck ! i have these errors message i hope you can help , i also have managed to put travel mode and " bend light option" but need to code the afs
also cornering lights not working ? not sure why no mfd errors about cornering lights
im trying to make it do basic settings but not working ! getting errors
pictures below
any advice ?
thanks in advance ! thanks for the awesome guide just stuck on this dam afs lol
i do manage to start basic setting then this happens and nothing happens later
Roy_01
In: Sumatra
Post by Roy_01 »
Your module is coded for start stop vehicle.
Uncheck byte 01 bit 7 in AFS/xenon range module to get rid of the U112100 fault.
The other fault is your rear level sensor, check if you can solve this problem and erase faults afterwards.
Thats why you cant do level calibration.
mrsavvy90
Post by mrsavvy90 »
thank you so much mate ! you the best ! i will try tomorrow morning thank you so much
toreddu87
Options: Airlift performance - 3p - allestimento r facelift - monitor 2 din alpine da 8 pollici
Post by toreddu87 »
hi guys I have a scirocco of 2013 with halogen headlights .. my bcm and a final 086q .. I have already bought the headlights and wiring kufatec .. I read that you have to change it .. connecting pin 8 to pin 11 and making a bridge from pin 8 to pin 12 and right? I'm interested in having only the bixenon and the drl in the lighthouse. Thanks in advance
Roy_01
In: Sumatra
Post by Roy_01 »
What you can do is use the high beam wire pin 8 of your old lights and connect it to the shutter pin 11 of the new lights. Pin 10 and 12 are the drl and side light wire. They need to be connected to the bcm. Without coding you also need to bridge pin 10 and 12 on both sides to turn them on.
toreddu87
Post by toreddu87 »
I connected pins 8 10 and 12 to the positive drl .. and pin 8 to pin 11 .. everything works .. only the LED flashes when the engine is running. why ?
Roy_01
In: Sumatra
Post by Roy_01 »
Pin 10 and 12 need both side light and drl signal bridged if you want to run without dimming.
Also check if pin 5 and 7 have ground wires connected.
With VCDS check byte 15 bit 6 drl via seperate lights active.
If you want it to function as OEM:
First byte 18 module 09 has to be set to 00 with VCDS. Then use vag can pro PQ35 BCM programmer function.
Then setup side marker lights (A44, C26) and DRL (C4, A26) for both functions. DRL and sidelight dimming has to be set to value 2.
In module 09 check byte 27 bit 2 with vcds: Led daytime running light module for parking light and DRL.
toreddu87
Post by toreddu87 »
hello my configuration and right pin 8 10 12 connected to the positive drl. it works all but I would like the drl to drop in intensity when I turn on the low beam as I can do.? just change the intensity with vag can pro a44 c26 and c4 a26? and set to 2?
Roy_01
In: Sumatra
Post by Roy_01 »
You have to connect drl to pin 8 and 10 and side light to pin 12.
Then see 1 post above. Drl dimming value set to 2.
I think only A44 and c26 because the drl can just run on full brightness.
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Post by davidscirocco »
how do you set the value for dimming to 2?
Roy_01
In: Sumatra
Post by Roy_01 »
Dimming or brightness,
davidscirocco
sport pack
RCD 510
ok so in the 2nd picture on c26,a44 on Dimming instead of 10 as is shown in the picture i have to type 2 and save it and thats it?
Roy_01
In: Sumatra
Post by Roy_01 »
This is just an example picture, drl dimming setting on 2.
Values can be adjusted by personal opinion. But 2 will let the drl function without problems with flashing leds.
Just make a back up and photo before changing things.
When fitting newer facelift bcm also check if you parking lights still work (indicator on with ignition of).
I had to enable stand light functioning as parking light.
And also rear fog was on all the time.
davidscirocco
sport pack
RCD 510
ok will check. now that you mention it. when changing the bcm and installing facelift tail lights do i still need to change settings like foglight and park lights?
Roy_01
In: Sumatra
Post by Roy_01 »
I don't know i don't have a facelift rear.
davidscirocco
sport pack
RCD 510
oh ok ill let you know then how it went :P
toreddu87
Post by toreddu87 »
Roy_01 wrote:You have to connect drl to pin 8 and 10 and side light to pin 12.
so my configuration is wrong ?? pin 8 10 and 12 together with the positive drl I do not understand
toreddu87
Post by toreddu87 »
what do you mean by side light ??? where is the 12 pin ???
davidscirocco
sport pack
RCD 510
he means side light bumper where your turn signal. from pin 12 of your headlight you need to connect it to the side light
Roy_01
In: Sumatra
Post by Roy_01 »
toreddu87 wrote:what do you mean by side light ??? where is the 12 pin ???
Download the basic equipment from may 2008 document and see the wiring diagram.
https://www.dropbox.com/sh/nerw5cwkh9ug ... urFaa?dl=0" onclick="window.open(this.href);return false;
