My friend Bianco, it is easy.bianco wrote:Please enlighten the rest of us - how-to or pics pretty please!
At first you have to connect 3 cables of the Kufatec loom to your car :
1. The cable marked with “steady plus” (or RED colored) must be pulled to the fuse box & connected at a free +12V position with a separate fuse (5A).
2. The cable marked with “ground” (or BLACK colored) must be connected to a suitable ground point.
3. The last cable marked with “pin 28” (or YELLOW colored) must be connected to BCM connector , outlet C (is the brown connector) to pin 28 (Blue/black wiring color). From this one, loom gets the reverse signal. (In order to be sure that you have found the correct point, you can check that in this cable you must have +12V only when you select reverse).
About the problem of the wiring .You have to change the order of the 26pin female connector’s wiring, as is in the diagram.
Disassemble the connector
carefully remove the pins from the positions that are already installed
& re-install them to the correct positions :
• Pin 12 --> Blue
• Pin 13 --> Green
• Pin 24 --> Black (Not need to remove this one, as it must be already in the correct position)
• Pin 25 --> Brown
• Pin 26 --> Orange
Numbers are written on the housing ends like :
(Don't be confused by this image. It's from the male connector on the back of the RNS, just to see how the numbers are written)About VCDS coding, you must set :
• Address 10 – Coding - Byte 00 – Bit 5 : select “Rear view camera installed”
• Address 56 – Coding - Byte 03 – Bit 6 : select “Back-up camera low (without control module) installed”
& finally don't forget to "reset" your RNS.
That's all. Hope my post help you to fix your camera.
If you have any further question , just ask me
