Volkswagen CC has got the same interior door handles. Not too sure if its possible to order them and fit them in the scirocco.uklee wrote:Thanks Yyb ! - especially for the web links![]()
1. You have to change the wiring on the BCM and swap the DRL with the indicators.
I already have Bi-Xenon headlamps fitted as standard - is it still necessary to change the wiring on the BCM ? or can this change be done with VCDS ? - Do you know the required coding changes ?
3. I've soldered a red LED on the window switch lighting and put them behind the small cap right above the door handle
Could you please post a couple of pictures of how yours look now ( day / night )
Lee
YyBs Black Pearl - Converted to facelift with Lane Assist
Jaystarx
Re: YyBs Black Pearl
Alexanderrr
YyB, do you know if the facelifted rear bumper will fit the pre-facelift? Or only when you got the Lid and Lights?
They have nearly the same shapes?
YyB
Hi. It only fits with the new lights an lid.
i send you a PM mate
Did you get the facelift tail lights to work? Do you need a different loom or just adapter plug?
Those rims are the bomb!
eebpwoojpoy
Great car, mate! I want to retrofit the restyle headlights too. Can you please tell me, what control unit should I use?
Отправлено с моего iPhone используя Tapatalk
YyB
@iDrive
The tail lights work like a charm on the MY09 Scirocco. Just need to recode the central electrics and change the connectors.
@eebpwoojpoy
Which MY do you have?
@eebpwoojpoy
eebpwoojpoy
2012.
@YyB I'm struggling with the rear led tail light connector! Can I just get a plug and use existing wires from the standard tail lights? How did you manage to find a connector? Thanks
Rob
Since you've got the aps function working, do you have "travel mode" within the lights section on the mfd?
YyB
@eebpwoojpoy
Ok, there is quite a lot to change than.
@iDrive
You can get the connector from your local VW spare parts dealer. You can use the old wires but if you have a Scirocco with the White cluster you'll need to change your BCM and the wiring between the BCM and the tail light.
@Rob
Actually I don't know. I still have the old red small cluster on my car but I've seen that option on VCDS.
@iDrive
@Rob
eebpwoojpoy
@ Yyb do you know, what exactly should I change?
YyB
You'll need to change your BCM, the xenon range ECU and the wiring between those control units and the headlights.
eebpwoojpoy
do you know numbers of those parts?YyB wrote:You'll need to change your BCM, the xenon range ECU and the wiring between those control units and the headlights.
YyB
- BCM: 5K0 937 087 AB
- ASF ECU: 5M0 907 357 F Z0R (05/14 or later)
- Connector for AFS: 7M3 972 726 B
- Sensor for xenon range: 1K0 941 273 L
- Left headlight: 1K8 941 751 B
- Right headlight: 1K8 941 752 B
- 2x ECU cornering light: 3D0 941 329 E
- 2x Xenon ballast: 8K0 941 597 E
- 2x ECU LED DRL: 4G0 907 697 J
I'm so glad that I've got one of the first Sciroccos
eebpwoojpoy
Yyb, thank you so much!!!
Отправлено с моего iPad используя Tapatalk
How have you do that mate?? for your rear light?
salvadi93
hello , how many things have changed in order to put the taillights facelift ? my compliments ,
I find you on facebook ?
aeromax25
What a nice conversion...
I'm pretty interested by the electrical fitting of the taillight, the old connectors are different from the new ones! What did you do to make them fit, do you have pictures?
