2010 Cruise Control
mike-p
Re: 2010 Cruise Control
Post by mike-p »
Ok I hope this is going to help.....
The old stalk is 5K0 953 521 D
It simply pulled off the column when the tags were released, no removal of security bolts/screws.
Life's too short to go slow
Skoda Yeti 4x4 Elegance 2.0CR
Shaun
Post by Shaun »
It looks to be a different part number to Dar's, yours is the same as mine
Thx for posting
Shaun
Post by Shaun »
Mike p What coding did you do ?
ashley1407
Options: Cruise Control, Metallic Paint, Fiscon Bluetooth, Bleep on locking.
Revo Remap.
Post by ashley1407 »
Thanks Mike! :)
DAR
Post by DAR »
Sussed it out!
In the pic below, look at the 3 yellow outlined areas, these are the 3 spring clips! Doh! Once released the stalks separate from the lock carrier.............Why do VW not sell just the stalks, instead of the whole assembly!
It wasn't obvious from the assembled stalks, just has a play in the garage! Anyhow it can retro fitted and coded to work.
Still stand the fact that a D version slip-ring and SW cont does not work! You need the H variant..............
armjcb
Post by armjcb »
How do I know what slip ring I have, is it somthing I can find out off Vagcom or is it a visual check with a partial strip down? though I suppose mine will be the D version that seems to be fitted as standard..... :?
DAR
Post by DAR »
You can find out using Vagcom. note - The Slip ring and steering wheel cont are combined. I would suggest that it is likely you will have a D version.
mike-p
Post by mike-p »
182_blue wrote:Mike p What coding did you do ?
If I recall we recoded the steering wheel controller, then simply checked the cruise function on the long coding helper.
dinger19
Options: Parking Sensors,mats,bluetooth.
Retro fit cruise
Post by dinger19 »
Hi, i've found this on the German Ebay site and was wondering would it fit a uk car.????
http://cgi.ebay.de/VW-Tempomat-Golf-6-S ... 1611wt_932" onclick="window.open(this.href);return false;
arlurt
Options: Changes will be made...
Puddle lights, Cruise and Reversing Camera on the cards.
Re: Retro fit cruise
Post by arlurt »
I bought my cruise stalk on UK eBay, thre are usually a few listed.
Then I used ture's guide to fit it, all went well, see below:
http://www.sciroccocentral.co.uk/forum/ ... =25&t=2228" onclick="window.open(this.href);return false;
Several people have had cruise retro-fitted by dealers, but shop around, they don't all charge the same.
panhandle
Options: Everything bar the panoramic..
Re: Retrofitted Cruise Control post week 45 (2010) cars only
Post by panhandle »
I specced CC on my week 7 2011 R. When it was delivered I was told they misbuilt the car and forgot the CC (I was told that I should be grateful as some cars are misbuilt with the wrong colour!) That ineptitude aside I was told that it could be retrofitted at the dealers and they would phone me when the parts came in. I havent chased them as I've been reluctant to give my R to anybody or anything!!!
This has however prompted me to chase it up, so I will keep you posted, but they did confirm it can be easily retrofitted.
lordoftheriffs
Post by lordoftheriffs »
Shaun wrote:
lordoftheriffs wrote:Any news about the project? Does a new version of VAG COM help the situation or it can't be helped?
What situation ?, the programming is OK
I mean what exactly do you need to retrofit cruise control in 2010 cars because i didn't understand much from earlier posts? Do you need another controller as well as the cc stalk? What are the prices for both?
Shaun
Post by Shaun »
Yes you need new controller, new stalks and then it needs programming, if you get the parts from VW it will be around £260 ?, possibly a bit less, VWCruise are doing it for £300 fitted
richardmfearn1
Options: sunshine roof, reverse sensors
cruise control
Post by richardmfearn1 »
I'm a recent owner of a used Scirocco 2010. can anyone explain why VW can't retr fit a cruise control to my car even though they were available on earlier models. Also went to have fitted a 'hands free kit' and instead of having with controls from the steering wheel and the central screen they fitted a tacky add on LCD screen on the dashboard, what a load of crap.
Dissapointed from Bath
RW1
Legend
Hi from Sunny Stopfordia
Re: cruise control
Post by RW1 »
:welcome:
Basically they changed to the electronics and design in the steering column and haven't provided a retro compatible kit for post week 45 2010 build Sciroccos.
29 Oct'09 at dealers
Driving 4th Nov. Sorted!
Ian_Mac
Options: 19" Lugano's, RNS 510, Leather, Winter Pack, Reverse Sensors, Electric Seats, Dynaudio, Bluetooth, Cruise, Xenons, Electric Folding Mirrors, Metal Pedals. Sadly gone now. :-(
Re: cruise control
Post by Ian_Mac »
Fitting Bluetooth isn't a major issue and the newest VW integrated unit is a fairly easy retro fit. All the parts can be bought new on eBay for just over £200ish.
As for cruise for a 2010 model it can be done, have a little search - from memory it's mike-p who has done it.
I had cruise retrofitted by the dealer when I bought mine, initially they said couldn't but luckily mine was just before the deadline being a 59 plate.
They did give a reason of cruise as a retrofit having to get separate approval or something - sounded fishy to me.
Ian_Mac
Re: cruise control
Post by Ian_Mac »
richardmfearn1 wrote:Hi,
Did you use Bath VW for the work? I've just had mine serviced there and was really impressed with the service/efficiency.
:clap:
Shaun
Re: cruise control
Post by Shaun »
£300 fitted by these chaps http://www.vwcruise.com/129.html" onclick="window.open(this.href);return false;
fattyboombalatty
In: Night Blue
Options: Rear Parking Sensors, Cruise Control, Folding Mirrors, Smokers Pack, Front and rear Mudflaps, Fiscon, RNS510 video in motion enabled, VW Bluetooth.
Re: cruise control
Post by fattyboombalatty »
Shaun wrote:£300 fitted by these chaps http://www.vwcruise.com/129.html" onclick="window.open(this.href);return false;
Had it done by these guys too. Great job, very professional. Even came out to me to do it.
richardmfearn1
Re: cruise control
:clap:
Nah, Mann Egerton Swindon, that's where I bought it
