Using a 'Snap On Solus Edge tester' it showed 2 faults.
00776 Level control system sensor Left Front (G78) Open Circuit/Short With Power.
01769 Sensor for Vehicle Levelling Front Right (G289) Open Circuit/Short With power.
1. Has anyone had the same or similar problem?
2. What was the solution please?
TIA
DCC Switch Blinking
- In: Night Blue
Re: DCC Switch Blinking
Hi, I had a similar problem and if you look behind the back of the wheel there is a little plastic ball ball and socket joint on a arm mine had come off..... I took the wheel off reattached with a little grease and had no problems since, hope this helps
Sent from my SM-G986B using Tapatalk
Thanks for the suggestion. I've examined both units. They look OK.
1. Does this particular circuit have a fuse?
2. What's the best method to test them with an electrical meter?
3. Is it likely that both would fail at the same time?
