Next time you open the boot of your rocco, can you check if the passenger rear cluster is slightly further away from the body than the drivers one, also can you check the bolt attaches around the body of the boot as mibne look slightly rusty already?
Being really picky but want to make sure mine is a goodun.
Roc on
rear cluster, passenger side slightly out
- adamj
Re: rear cluster, passenger side slightly out
Sounds like your as picky as me
Will check mine tomorrow for you and report back
