Anyone able to identify this issue?
Kttmmbb
Options: Ricaro seats
Post by Kttmmbb »
I have my 16 plate scirocco booked in at VW next week due to an air bag error message coming up on the dash.
I did a tight turn and sounded like something popped in the steering wheel (wires, unsure really). Ever since then it's been struggling to start and coming up with lots of lights on the dash that then go away.
Had a diagnostics and no codes came up.
Has anyone else had these sorts of issues?
deaconm
In: Indium Grey
Options: n/a
Re: Anyone able to identify this issue?
Post by deaconm »
It could be the clock spring, I'm not a mechanic but as far as I'm aware the clock spring keeps wires for electronic controls on the steering wheel in constant tension (including wiring/cables for the airbag) . I had a similar issue recently but it was an electrical fault not mechanical, it sounds like something has snapped/broken inside the steering wheel/column which would be flagging the airbag warning light.
Kttmmbb
Post by Kttmmbb »
VW have said it's the slip ring. Quoted £700.
deaconm
In: Indium Grey
Options: n/a
Post by deaconm »
Kttmmbb wrote: ↑Wed Mar 05, 2025 2:28 pm VW have said it's the slip ring. Quoted £700.
Not sure if the terms slip ring/clock spring are used interchangeably, but from the quote and the issue you described it sounds similar to what I had.
As far as I'm aware there's no way around that cost unless you know what you're doing and can fix it yourself, I was charged a lot for labour costs as they needed to take the steering column apart to get to it.
sciroccomods
Options: Mk8 R heated wheel,
Porsche 18z 6 pots
Sequential animated Bi-xenons,
Sequential animated rear lights
Electric cooling/massage/memory Leather seats,
auto dimming power fold mirrors,
virtual cluster,
Dynaudio,
panoramic roof,
Dcc,
Direct tpms,
Blindspot assist,
Acc,
Lane/Sign/high beam assist,
Post by sciroccomods »
deaconm wrote: ↑Fri Mar 14, 2025 2:26 pm
Yes clockspring/squib is the same item, i retrofit cruise control for £250 fully fitted and coded, and that includes a clockspring, stalks, fitting and coding. so miles cheaper and cruise control .
I offer Power fold mirrors installs, Cruise control installs, Coding, mirror folding on keyfob etc. i'm in Stockport,Manchester
