Does anyone know the Torx size of the pinch bolt ?
Need to remove shocks
Front Shock pinch bolt size
bigkris06
Re: Front Shock pinch bolt size
I assume you mean to remove the nut on top of the strut? I use an old piece of inner tube on the shock itself (to protect it) and clamp it with mole grips then use either a socket and ratchet or an impact to remove the nut… obviously when the springs are compressed.
