Inlet manifold sensor failure, £600 to replace!?
J37F1R3
In: Salsa Red
Re: Inlet manifold sensor failure, £600 to replace!?
Post by J37F1R3 »
"They finally made a revised part for the intake manifold with a new design for the actuator arm and a different position sensor.
Part number: 06J133201BH
So ask VW if you get this part and not the old version."
Hi All will the above manifold as mentioned by roy_01 fit my SCIROCCO GT 2009 2.0 TSI?
Thanks in advance
Paradox1
Post by Paradox1 »
im guessing so as only the TSI 2.0 engines has this fault. the scirocco R used a rod arm instead of accuator
