Hello to you all.
I have an issue with my revs jumping around just as it gets to idle speed. Also it hangs up just under 2k for a very short time, it doesn't do this all the time. Once at idle the revs are fine. I'v tried the removal of the dip stick trick, all seems well with that test. I have also checked the idle control valve which is fine.
I have purchased a GFB pv valve today, that will be with me on Friday. But as I have it in bits I was going to replace the PCV also.
So, where would you guys get yours from, not keen on the forge delete plate, or what ever its called as I want to keep all the stock wiring in place. Do you think these two things will rectify my problem????
Richard
PCV Scirocco R
mvb12
- In: Pure White
Re: PCV Scirocco R
OEM PCV from VW or TPS
Personally if you have an R, I would stick with the OEM DV REV G.
Have you done the dipstick test?
