aux and usb not working.
RikkiT
- In: Silver Leaf
Hi, I haven't the slightest why the Aux or Usb port isn't working. i'v got the rcd150 and currently using cds
would it need an update? iv heard a little bout the mdi lead but i need some advice. cheers
EvilMr.Lee
Re: aux and usb not working.
Have you tried checking with VCDS?
I found out my unit was not coded, and AUX was disabled. I haven't tested the aux after I enabled it though, as I only use bluetooth.
RikkiT
- In: Silver Leaf
I'll check that it I'm pretty sure the guy I brought it off said it has been coded...EvilMr.Lee wrote:Have you tried checking with VCDS?
