- Daddydub140
Today I gave my mats a good cleaning, the mats were absolutely filthy. Decided to use that that " Vanish Shake and Clean" and it does an extremely good job, after vaccing the mats looked almost new again.
Thats one cleaning product I shall be keeping in my detailing product bucket.
- Daddydub140
1 .Had to change my battery (72Ah from a 61Ah) and took opportunity to install the plastic battery box, engine bay looks cleaner and so much better, found it an easy mod.
2. Swapped mirror caps to black, another easy mod thanks to Uklee ford his thread on the subject cheers Lee.
going to Boro tomorrow so no work Sunday
- Roy_01
Installed the seat heater mats in both front seats with the wiring looms.
Took about 6 hours hell of a job to take the seats and clothing apart but very satisfying.
Now the next step to get a warm ass is to do the wiring in the car.
Im going to use the golf 6 seat heater wiring loom from kufatec.
- In: Night Blue
Fitted a new carbon fibre bonnet (xmas present to myself), then had it wrapped to match.
Can really hear the turbo now with the vents!
Cheeky rear shot as well
Encoded XDS. Damn, should have done it earlier! There is a massive difference (traction in corners).
New to this all! But picking up my first Scirocco Saturday... buzzing
- Willyjay212
I done all my front lights today
To super white
They are brilliant
such a difference can actually see the road now [emoji14]
Sent from my D6603 using Tapatalk
To super white
They are brilliant
- In: Night Blue
Xenons or standard?Willyjay212 wrote:I done all my front lights today
To super white![]()
They are brilliantsuch a difference can actually see the road now [emoji14]
Can I ask which bulbs you used for dipped and main beam if the latter?
- Willyjay212
Want me send you the link on eBay?RYANWOOD4 wrote:Xenons or standard?Willyjay212 wrote:I done all my front lights today
To super white![]()
- Willyjay212
To super white![]()
- In: Night Blue
Yes please.Willyjay212 wrote:Want me send you the link on eBay?RYANWOOD4 wrote:Xenons or standard?Willyjay212 wrote:I done all my front lights today
To super white![]()
Can I ask which bulbs you used for dipped and main beam if the latter?![]()
I've tried so many bulbs claiming to be bright white...they've all been crap and yellow!
- Willyjay212
Here's the item number matey
231480701327
Only thing they don't include is fog lights but you can get same ones from same guy for 6pound something heres the other item code for that
231245879436
231480701327
231245879436
- Willyjay212
EBay now
- In: Night Blue
Cheers. Purchased a set. Can't go wrong for £8!Willyjay212 wrote:Here's the item number matey
231480701327
231245879436
I don't have fogs, so that's fine.
- Willyjay212
I know matey!RYANWOOD4 wrote:Cheers. Purchased a set. Can't go wrong for £8!Willyjay212 wrote:Here's the item number matey
231480701327
231245879436
There actually really good to! No yellow what's soever and the side lights are actually alot better they look like led lights!
- Roy_01
Installed the seat heating harness in the car this morning. Driver seat connector is finished, bcm, climatronic and ground wires connected. Only things to do is connect the passenger seat and 12v to fuse 37.
Could you tell me where did you get the seat heating harness? Any link?Roy_01 wrote:Installed the seat heating harness in the car this morning. Driver seat connector is finished, bcm, climatronic and ground wires connected. Only things to do is connect the passenger seat and 12v to fuse 37.
- Roy_01
I used a golf VI seat heating harness from kufatec. The loom to the passenger seat is a little short so have to extend it 20-30cm but only 3 wires so not that difficult. See this topic:
http://www.sciroccocentral.co.uk/forum/ ... =2&t=21724" onclick="window.open(this.href);return false;
- easyrider
cam follower replaced
