Faulty passengers window
Postby LJP1991 » Sat Oct 21, 2017 1:52 pm
Hi all.
11 plate scirocco R
When getting out the car today my partner said the door felt weird. She pushed it and now the window will not operate at all. Won’t go up or down. Doesn’t move when opening the car like normal.
Has anyone had this issue before. Any advice much appreciated. Currently can’t lock my car!!!
Local be garage has closed for the day!
Liam
LJP1991
Options: Panoramic Roof, 19", Vienna Leather, Parking Sensors (Front & Back(, DAB, Dynaudio, Folding Mirrors, Xenons.
Re: Faulty passengers window
Postby Babajang » Sat Oct 21, 2017 2:01 pm
No idea about the window problem but have you tried locking the doors using the physical key? there is a little panel u can pop off on the door handle to get to the slot.
Babajang
In: Indium Grey
Postby Cuprabob » Sat Oct 21, 2017 5:29 pm
It probably felt weird because it didn't drop before opening so the door would have had to be pushed against the seal.
One thing you could try is to disconnect the battery for a period then reconnect to see if the door module will reset and allow the window to work.
Note if you do try this, then fon't worry when a couple of warning lights stay on when you first start the car. They will go.out after you drive the car a few hundred yards and the steering angle sensor calibrates.
Postby chelspeed » Sun Oct 22, 2017 10:50 am
Isn't there a window reset? Something like open it fully then press the open button again for 2s then close it fully and then press the close button again for 2s?
chelspeed
Options: Sold it!
Postby LJP1991 » Mon Oct 23, 2017 2:26 pm
Thanks, will try the battery disconnect.
RE Dropping the window, the window will not move at all. Its stuck up. Even using the car key which opens all other windows.
LJP1991
Postby PWRoccoR » Wed Oct 25, 2017 7:29 pm
Had this exact problem at the end of last week in my R, Was into VW yesterday and had a new window switch fitted under warranty.
PWRoccoR
In: Pure White
Return to Scirocco R Talk
Who is online
Users browsing this forum: No registered users and 17 guests
