Which petrol for the R?
- RoccoTom
After nearly 300 miles in my new R, it's time to fill the tank for the first time...
What petrol are people using in their R? I know the sticker on the fuel cap recommends 98 (or super unleaded), but surely 95 will still do the job - especially if you drive the car economically? I have easy access to 95 unleaded, but not necessarily to 98.
- In: Pure White
Re: Which petrol for the R?
I use tesco super when l put normal stuff in doesn't feel as urgent
- whiteDevil_170
I wouldn't put 95 in.
Stick to what the cap says. 98.
Or super.
Or super.
Jack
Lets Roc
Lets Roc
- RoccoTom
The cap does say '98 (95)', as if to suggest that 95 would do. The guy at the dealership also said 95 is perfectly fine, but just thought I'd see what the drivers themselves reckon... Any noticeable difference in the way it drives?whiteDevil_170 wrote:Stick to what the cap says.
Sainsburys super for me and if I feel posh, I'll use shell v power. Nothing less
- RoccoTom
Glad you mentioned Shell V-Power, as there's a petrol station on my commute which has that. So you'd recommend it?shrink wrote:Sainsburys super for me and if I feel posh, I'll use shell v power. Nothing less
Oh it's the best by far IMHO it's just chuffing expensive here.
Sainsburys super unleaded works well and is £1.04. Vpower is £1.15 and that's just a bit much for every single fillup
- In: Pure White
Only V Power for me
Any turbo petrol car will benefit from a higher octane fuel
Personally I switch between Sainsburys SUL or BP Ultimate, just depends what is handiest.
Unfortunately in Northern Ireland we do not have access to Tesco Momentum or Shell V-Power
95 ron is ok for the car but ideally 97+ is better for performance and economy.
Also, if you bought the car for economy, you made the wrong choice!! Fuel is cheap as it has ever been in the last 6 years lol
- In: Oryx White
Shell V Power only for me too! It's the only fuel I've used in my last 3 cars.
V power only, its worth the extra.
Why buy a car like this if you want to save a few pennies and not treat it to the right fuel.
- In: Pure White
Totally agree with that
- charliegilmanuk
Even on my 2.0 TSI GT I notice the difference between shell unleaded and shell vpower, throttle is less 'lumpy' and I've definitely gained 2-3mpg since using it (all recorded in an Excel spreadsheet ).
- Phil
- In: Night Blue
Nothing but shell V power for my R or my old GT. It occasionally gets something else if I get caught out, and if that happens and there's no super, it gets a 10er of the usual crap which is enough to get me to a shell garage haha
Phil
I only use BP if i have some extra cash ill get ultimate
- Jojreynolds
V power on every fill up, if I'm away then will use any other 98+ but the car fills happier on shell.
- 3t3p
V power.
Did use momentum in the past too.
Don't forget, triple points on shell v-power at the moment!
Super unleaded only. You otherwise run the risk of pre-ignition (knocking) which can ultimately damage the engine (pistons, cylinder wall etc.).
Engine has knock sensors which retard the ignition to prevent "pinking" if 95 grade fuel is used.MrBarry123 wrote:Super unleaded only. You otherwise run the risk of pre-ignition (knocking) which can ultimately damage the engine (pistons, cylinder wall etc.).
