Swirl Marks
Swirl Marks
Hi All!
Just purchased a new (used) rocco, and the paintwork in parts is appalling, on the driver side door it looks like someone has taken a sponge filled with grit and rubbed it on the car What is the best way to, at least improve this!
The car is black! so shows everything
thanks
thanks
Re: Swirl Marks
Take it to a local detailer and have a paint correction done.
The other option is to go over to detailingworld.com and learn about wet sanding and polishing, if you are so inclined.
Re: Swirl Marks
Ok, thanks, I will try and find a decent local detailer! I wouldn't mind trying myself however I'm always concerned about making it worse! Thankyou!
Re: Swirl Marks
If you give your rough location, maybe someone will be able to recommend one in your area.
Re: Swirl Marks
Good shout, thanks! Based near Portsmouth in Hampshire!
- Phil
- In: Night Blue
Re: Swirl Marks
Wet sanding probably is a bit to much for swirls but bob is right. DA polisher, patience and some polishing compound finished off wish a good wax & sealant should sort it out. I would do some research before hand, DA's can cause more damage if used incorrectly
Phil
Re: Swirl Marks
Done some research, and contacted some local valeting companies, been quoted about £500-600 for a "two stage paint correction" - I have taken a look and think I will have a go myself, only concern is the paint thickness. I don't want to be overzealous and take too much off!
Thanks for the advice!
Re: Swirl Marks
If you use a DA rather than a rotary polisher the likelihood of doing any damage will be dramatically reduced. It will take longer though.
The be fair they're reasonable prices for a two stage correction as it will take several days to do.
Re: Swirl Marks
I've got a DA which I am able to borrow! Just been researching products / compounds etc!Paddy_R wrote:If you use a DA rather than a rotary polisher the likelihood of doing any damage will be dramatically reduced. It will take longer though.
Hmm does it? I was under the impression they would do it in a day! I'll have to question them a bit more!
Re: Swirl Marks
Look at Maguires 105 & 205 compounds. They're great to work with and give excellent results.
Re: Swirl Marks
You can do it in a day, I did mine in a day and applied Crystal Serum.STEVIE-B wrote:I've got a DA which I am able to borrow! Just been researching products / compounds etc!Paddy_R wrote:If you use a DA rather than a rotary polisher the likelihood of doing any damage will be dramatically reduced. It will take longer though.
However I had already polished my car before so it did not need a heavy correction and I only needed to do a refinement rather than an outright correction.
You can easily spend 25-30 hours doing a 2 or 3 stage correction especially on some cars with harder paint types. Generally around £250 (ETA: per day!!) is around the right money for detailing.
Re: Swirl Marks
As I know I won't get a chance to do this for about 3 weeks I had a little bash at getting the worst scratches out on Friday! Pretty happy with the results considering I did it by hand in about an hour! [emoji4][emoji106]I know it's not fantastic but think I have done well considering it was my first attempt! Before and after pictures below!
EDIT - How on earth do I resize these
- In: Shadow Blue
Swirl Marks
Not for 25-30 hours work it isn't. You'd be lucky to get single stage work for £250.xjay1337 wrote:
You can easily spend 25-30 hours doing a 2 or 3 stage correction especially on some cars with harder paint types. Generally around £250 is around the right money for detailing.
Three stage correction:
Re: Swirl Marks
Mr OCD wrote:Not for 25-30 hours work it isn't. You'd be lucky to get single stage work for £250.xjay1337 wrote:
Oops, I should have said "per day".
I used to do detailing so I should know.
Generally around £500 for a Scirocco sized vehicle, and £600-700 with a coating depending on what coating you go for lol
Re: Swirl Marks
Couldnt complain if it was for 25-30 hours work. The place I went for a quote said it would be done in a day, drop it off at 8am and pick it up after work. Thought £500-600 was high for just one day, if it is generally a few days and takes this sort of time it makes more sense!Mr OCD wrote:Not for 25-30 hours work it isn't. You'd be lucky to get single stage work for £250.xjay1337 wrote:
- In: Shadow Blue
Re: Swirl Marks
xjay1337 wrote:Mr OCD wrote:Not for 25-30 hours work it isn't. You'd be lucky to get single stage work for £250.xjay1337 wrote:
I've been detailing for over 10 years now long before all the cowboys jumped on the bandwagon, these days I just do it part-time to keep my arm in ...
- In: Shadow Blue
Re: Swirl Marks
That depends on variables. i.e. it might be done in one day and £500-£600 but you could have 2-3 people working on it, rather than one person working 2-3 days.STEVIE-B wrote:Couldnt complain if it was for 25-30 hours work. The place I went for a quote said it would be done in a day, drop it off at 8am and pick it up after work. Thought £500-600 was high for just one day, if it is generally a few days and takes this sort of time it makes more sense!Mr OCD wrote:Not for 25-30 hours work it isn't. You'd be lucky to get single stage work for £250.xjay1337 wrote:
Going rates are about £250 - £500 per day depending on who you use and where.
Ceramics start at about £100 and can go up to over £600-£700.
Re: Swirl Marks
Makes sense, thanks Mr OCD. (y)
Re: Swirl Marks
STEVIE-B wrote:As I know I won't get a chance to do this for about 3 weeks I had a little bash at getting the worst scratches out on Friday! Pretty happy with the results considering I did it by hand in about an hour! [emoji4][emoji106]I know it's not fantastic but think I have done well considering it was my first attempt! Before and after pictures below!
What polish/compound did you use?
Re: Swirl Marks
I'd have that sorted in a full day with a rotary, Flex 3401, Lake Country purple foamed wool pads, Scholl Navy pad, Scholl S3 Gold XXL and Scholl S40. Paint thickness measurements taken first. In my experience, a Scirocco has around 130 microns of paint which is decent to work with unlike some Japanese cars where the paint is less than 80 microns.
