Xenon retrofit
kem86
Xenon retrofit
Post by kem86 »
Morning everyone
I am carrying out the pre facelift bi xenons everything is 2nd bcm and lights apart from the harness.
Do i need vagcom(vcds) or vcp to program my keys
Thank you
Sent from my SM-G960F using Tapatalk
davidscirocco
Options: panorama tilting roof, electric
"interlagos" alloy wheels
sport pack
RCD 510
air-contition Climatronic with dual- zone climate control, left and right side separately controllable
Re: Xenon retrofit
Post by davidscirocco »
Yes you need vcds to program your keys
kem86
Re: Xenon retrofit
Post by kem86 »
Sweet thank you because i am using a 2nd hand bcm didnt know if i needed vag com or vcp to do it
davidscirocco
sport pack
RCD 510
Re: Xenon retrofit
You got to make a backup of your old bcm and then change to to the other bcm you have with vcds and then you can program your keys
kem86
Re: Xenon retrofit
Post by kem86 »
Ok thank one more thing how do you program indicators to stay on as sidelights
heimer
In: Urano Grey
Options: Gunmetal grey wrap, upgraded LED tail lights (sequential), Upgraded LED DRL upgraded head unit with android auto, apple carplay, 18" wheels, black wrapped mirrors, 20" sub woofer.
Re: Xenon retrofit
Post by heimer »
kem86 wrote:Ok thank one more thing how do you program indicators to stay on as sidelights
Using a VAGCom, Obdeleven, etc. You need to access central electrics, then it should just be an option, something like "turn signals on permanently".
Sent from my SM-N950F using Tapatalk
kem86
Re: Xenon retrofit
Post by kem86 »
Thank you
