Oil pressure warning
Rocco91940
Post by Rocco91940 »
Hey guys my scirocco randomly flashes oil pressure stop engine but it seems to be running fine. It only seems to happen when oil seems to be about 97 °c and at just under 2000rpm . Would you say it was sensor or oil pump
Phil
Re: Oil pressure warning
More than likely the pressure sensor or the wiring to it but best to get the oil pressure measured mechanically to be safe incase it really is low pressure and risk damage.
I would also do an oil and filter change incase there is a blockage in the filter.
Rocco91940
Allready done a oil and filter change with some engine flush i was thinking sensor because if was pump wouldnt it do it all the time?
xjay1337
Post by xjay1337 »
I wouldn't drive it until you have had it properly investigated
Check oil pickup in sump, it's common after engine flushes to block the pickup pipe.
Check oil pressure manually.
click for build thread
racetech
Options: panoramic roof
hd lights
reverse sensors
folding mirrors
puddle lights
Post by racetech »
had the same thing on mine 2.0tsi,,ended up being the balance shaft bearing housing,,,,a bolt had come out,,the bearing assembly kept moving out of its journals,,intermittend low oil pressure,,,junked the engine ,,,,,,,,,
Rocco Neil
Options: interlagos18's , rear parking sensors , cruise , folding mirrors , privacy glass puddle lights start stop climate control AP coilovers
Post by Rocco Neil »
I had a similar thing on an A3 but it was oil level warning . Garage told me it was the oil level sensor . £164 later turned out to be a five amp fuse . Most expensive fuse in the south wales valleys lol . Worth a look though .
Rocco91940
It seems to be running fine its only now and again well say driving about half hour 40 mins and always about 97°c it happens and around 2000rpm
Rocco Neil
My A3 ran sweet as , but the blown fuse caused not only the oil level warning to come up on the dash , but it knocked out the reverse light and the parking sensors . It maybe worth a gander at the fuses even if its to rule it out . lets be honest , a cheap fix is always a better option .
Rocco91940
Took the sump off oil pick up is clean changed the sensor as cheap fix and seems to have sorted it touch wood cheers for the help guys
