need help , stage 1 clutch for scirocco 1.4 tsi 160 hp
ehab
In: Shadow Blue
Post by ehab »
the clutch started to slip 5 days ago , first i noticed that on odd gears 3 - 5 -7 and when i kick down full throttle i feel that the car hardly changes gears and the power loss .
my car is 1.4 tsi 160 DSG stock 100%
i am planning to have revo stage 2 software so i will upgrade intake , exhaust , intercooler , and spark plugs . And as my clutch started to slip so i wanna ask which sport clutch kit is the best choice for me and stage 1 or 2 ? and is there any thing concerned to the clutch should i get it too ?
blower
Re: need help , stage 1 clutch for scirocco 1.4 tsi 160 hp
Post by blower »
There is only 1 aftermarket clutch pack available for the 7 Speed dry clutch DQ200 DSG :
http://www.tmg-performance.com/en/produ ... evlar.html" onclick="window.open(this.href);return false;
Also that is only available for DSG boxes manufactured up until mid 2011.
Usually it shouldn't be necessary to change the clutch even for a stage 2 - but if you have one of the older clutch packs (pre 2012/13) then it was made of a weaker clutch material that is far more prone to wearing out and slipping.
ehab
In: Shadow Blue
Post by ehab »
thank you very much :) ))
ehab
In: Shadow Blue
Post by ehab »
blower wrote:There is only 1 aftermarket clutch pack available for the 7 Speed dry clutch DQ200 DSG :
thanks you a lot bro :) , i was searching for this topic week ago but without result , all clutches i had found were for 2.0 tsi :D
You said that cars pre (2012/13) had weaker clutch. My car is 2011 so i had this weaker clutch. My question is Can i get the newer clutch that is in models (2012/13) and intall it in my car ? and this clutch can handle revo stage 2 power (up to 225ps) ?
i would go with that option as u said it's not necessary to get sport clutch and actually TMG clutch is expensive .
Grande
Post by Grande »
Is it necessary to get the toolkit for the TMG clutch pack assuming VW would do the replacing? That's an extra cost.
http://www.tmg-performance.com/en/produ ... dq200.html" onclick="window.open(this.href);return false;
blower
Post by blower »
You can get the newer official clutch direct from VW, its part number 0AM198142B for a 2011 CAVD car manufacture date up to 31/05/2011
Its currently £565 Inc VAT. As above you need specialist tools to fit, but I estimate its a 4 hour job for VW so probably looking at another £500 for fitting - total around £1000
ehab
In: Shadow Blue
Post by ehab »
thanks for ur amazing info again blower :)
i'm going to change DSG transmission oil ,, i want to know how litres did it take ? for 1.4 tsi and what's the specs of oil like 75w80 or 90w80 ....... ?
xjay1337
Post by xjay1337 »
I would be very surprised if you have worn out the clutch on the DSG. They also don't really slip and can take lots of power in most cases.
Do a DSG oil change. Use OEM Oil and OEM filter. It's not a case of 75x90 or whatever. There have been issues using aftermarket oil and non genuine filters.
After the DSG oil change, do an adaption/reset of the gearbox using VCDS. I would be very, very surprised if this did not resolve your issue.
click for build thread
