DAB Adapter for RNS510
- Daddydub140
Hi Guys&Gals,
Can anyone tell me if there is such a thing as a Passover unit to enable the RNS 510 to use Dab radio,
Details of my RNS 510 :-
1TOO35680P
HW-version version H10
SW-version=5238
Map version HDD 8375
1TOO35680P
SW-version=5238
Re: DAB Adapter for RNS510
You can't add DAB to a non DAB unit as such. The hardware inside is not there for DAB radio. However, something like this might be of interest?
[youtube][/youtube]
[youtube][/youtube]
- Daddydub140
Thanks Viking for your information I will look into this when I've studied the utube inset, have you any Idea where this can be purchased or have installed .Viking wrote:You can't add DAB to a non DAB unit as such. The hardware inside is not there for DAB radio. However, something like this might be of interest?
[youtube][/youtube]
The bloke popped up on another forum advertising these and selling them, but I think Admin reckoned it was commercial and dumped the post as I can't find it any more. I'll go have another look.
Edit: http://www.sklep.martos.com.pl/radio-tu ... anguage=en" onclick="window.open(this.href);return false;
- Daddydub140
Viking, thanks for your help and guidance with this and I'll have a good look into it.Viking wrote:The bloke popped up on another forum advertising these and selling them, but I think Admin reckoned it was commercial and dumped the post as I can't find it any more. I'll go have another look.
Dave
One thing to consider, you could sell your RNS510 and buy a DAB one for about the same outlay, and have a system which doesn't have a doohickey fix. The RNS with DAB will be able to fall back to FM when it loses the DAB signal whereas the add on won't be able to do so.
- Daddydub140
Hi Viking now that's a worthwhile consideration well mentioned my friend once again thanksViking wrote:One thing to consider, you could sell your RNS510 and buy a DAB one for about the same outlay, and have a system which doesn't have a doohickey fix. The RNS with DAB will be able to fall back to FM when it loses the DAB signal whereas the add on won't be able to do so.
Dave
I see you're in Darlington. If I come across a DAB unit I'll let you know.
- Daddydub140
That's kind of you Viking thanks, I have been searching but have a concern with regards to Dab antenna.Viking wrote:I see you're in Darlington. If I come across a DAB unit I'll let you know.
Dave
What concern? Bear in mind that you'll also need a DAB antenna for the piece I posted earlier on.
- Daddydub140
The concern I have is, The two rear windows left and right which have very thin orange antenna like lines in them but are different in make up I also have the GPS roof antenna so concern is more confused what they are.Viking wrote:What concern? Bear in mind that you'll also need a DAB antenna for the piece I posted earlier on.
Earlier you saw I am in Darlington are you near by .
Dave
Just over in Richmond mate.
The rear window antenna setup isn't too complicated, but I'm not too sure personally how they're configured or which side specifically does what. Essentially you have two antennas and the radio selects the strongest signal from them.
- Daddydub140
Ok mate I think I'll have to wait until I get another unit and then sort it out.Viking wrote:Just over in Richmond mate.
Richmond, nice place I'm told, I've not long moved up here so still finding my feet.
Dave
