steering wheel module swap , epc light
MTR11
Post by MTR11 »
hey guys
just swaped my steering wheel moudle (2010 scirocco 1.4 tsi 160 ps), everything work exept that now my epc light turned i checked it on VCDS and here is the resualt:
Thursday,15,January,2015,17:25:41:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ13ZAV436543 License Plate:
Chassis Type: 13 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 BA HW: 03C 907 309 B
Component: MED17.5.5 9660
Revision: LAH07--- Serial number:
Coding: 0000077
Shop #: WSC 64867 768 16448
VCID: 61C3BDC4B8B76B16FBD-8034
3 Faults Found:
008801 - Boost Pressure Control Valve (N249)
P2261 - 000 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 12
Reset counter: 255
Mileage: 64729 km
Time Indication: 0
Date: 2055.14.02
Time: 12:53:27
Freeze Frame:
RPM: 1173 /min
Load: 6.7 %
Speed: 44.0 km/h
Temperature: 88.0°C
Temperature: 24.0°C
Absolute Pres.: 930.0 mbar
Voltage: 13.716 V
001299 - Incorrect Immobilizer Key
P0513 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 63855 km
Time Indication: 0
Date: 2054.14.12
Time: 16:13:35
Freeze Frame:
RPM: 1343 /min
Load: 7.1 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 47.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.811 V
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 000 - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 64899 km
Time Indication: 0
Date: 2055.14.23
Time: 00:01:33
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 4.0°C
Temperature: 6.0°C
Absolute Pres.: 920.0 mbar
Voltage: 11.557 V
Readiness: 0010 0001
Address 02: Auto Trans Labels: 0AM-300-04x.lbl
Part No SW: 0AM 300 048 N HW: 0AM 927 769 D
Component: GSG DSG AG7 431 2668
Revision: 00043014 Serial number: CU501307127406
Coding: 0000020
Shop #: WSC 00980 730 93473
VCID: 3B7F2FAC7A9B61C6811-806E
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 743B60F5612500002E1006E8861C0040310800
Shop #: WSC 00020 790 12345
VCID: 7AF1EAA8F52198CEDA7-802F
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS
Component: Climatronic H15 0709
Revision: 00003001
Coding: 0000001002
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_Climatronic A01006
ROD: EV_ClimaAutoBasis_SE36.rod
VCID: 7DFBE1B4EC0FAFF6FF5-8028
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 086 C HW: 5K0 937 086 C
Component: BCM PQ35 M 011 0028
Revision: BC011001
Coding: 40100A3890250A00408000800000012640703A88524D89605C 8008000000
VCID: 346D049097C5AEBE40B-8061
Subsystem 1 - Part No: 1K8 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 20110 22 0614
Coding: 009795
4 Faults Found:
00447 - Function Limitation due to Over-Voltage
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 146
Mileage: 64865 km
Time Indication: 0
Date: 2055.14.15
Time: 23:06:41
Freeze Frame:
Term 15 On
Voltage: 14.75 V
ON
ON
OFF
OFF
ON
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 2
Reset counter: 147
Mileage: 64871 km
Time Indication: 0
Date: 2055.14.21
Time: 17:00:36
Freeze Frame:
Term 15 On
Voltage: 14.45 V
ON
ON
OFF
OFF
ON
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 147
Mileage: 64871 km
Time Indication: 0
Date: 2055.14.21
Time: 17:00:50
Freeze Frame:
Term 15 On
Voltage: 14.55 V
ON
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 139
Reset counter: 150
Mileage: 60619 km
Time Indication: 0
Date: 2052.14.22
Time: 17:27:37
Freeze Frame:
Term 15 On
Voltage: 9.40 V
OFF
ON
ON
OFF
ON
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AE HW: 1K0 909 605 AE
Component: 0G AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 003D1D023EMS
Coding: 0012359
Shop #: WSC 00020 790 00000
VCID: 6FE7CBFC7E63CD667D9-803A
Subsystem 1 - Serial number: 6332MSME4E722F4BU
Subsystem 2 - Serial number: 6342MSME4E73022EI
Subsystem 3 - Serial number: 6352QSME324D3E2CU
Subsystem 4 - Serial number: 6362QSME424D4528K
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 569 H HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: --X01--- Serial number: 20120226301605
Coding: F980A00000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 3D7B21B4AC8F6FF6BF5-8068
14 Faults Found:
147462 - Terminal 15
B1148 12 [009] - Short to Plus
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
226827 - Turn Signal Switch
B1144 13 [008] - Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
226839 - Turn Signal Switch
B1144 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 110
227339 - Windshield Wiper Switch
B1145 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
227355 - Windshield Wiper/Washer Switch
B1149 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
229147 - Cruise Control Switch
B1154 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
332660 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
335876 - Powertrain Databus
U0002 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 110
Mileage: 64899 km
Date: 2055.14.23
Time: 00:01:34
336904 - Databus
U1122 00 [009] - Implausible Message
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
342020 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [008] - Performance
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
617736 - Selector Lever Park Position Lock Switch
B1162 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1K8 920 861 B HW: 1K8 920 861 B
Component: KOMBI H05 0308
Serial number: 00000000000000
Coding: 170B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 306508806BDD929E243-8065
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K102100348
Coding: ED801F06000202004000
VCID: 69D3A5E44087235623D-803C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0308
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EAD15AE80D81A84EAA7-80BF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1Q0 959 701 H HW: 1Q0 959 701 H
Component: Tuer-SG 009 2123
Coding: 0016437
VCID: 397335A470A753D693D-806C
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 69 3001
Revision: 00H17000
VCID: 31630D84A8D79B962BD-8064
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1Q0 959 702 H HW: 1Q0 959 702 H
Coding: 0016436
VCID: 3A712AA875A158CE9A7-806F
Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 HW: 5K0 035 190
Component: Radio RCD510 040 0167
Revision: 00000001 Serial number: VWZ1Z3K3008613
Coding: 0500040004
VCID: E2C132C8FDB1F00E627-80B7
End ---------------------------------------------------------------------
Saturday,17,January,2015,14:14:58:65217
15-Airbags -- Status: OK 0000
Coding: 0000077
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 64905 km
Time Indication: 0
Date: 2055.14.23
Time: 00:03:51
Freeze Frame:
RPM: 802 /min
Load: 9.4 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 24.0°C
Voltage: 14.097 V
Readiness: 1110 0101
Coding: 0000020
Revision: 00H30001
Revision: 00003001
Coding: 0000001002
Revision: BC011001
Coding: 009795
1 Fault Found:
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 111
Mileage: 64905 km
Time Indication: 0
Date: 2055.14.23
Time: 00:01:04
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
OFF
OFF
OFF
Coding: 0012359
Coding: F980A00000
6 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 111
Mileage: 64902 km
Date: 2055.14.23
Time: 01:16:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 64902 km
Date: 2055.14.23
Time: 01:16:46
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 110
Mileage: 64902 km
Date: 2055.14.23
Time: 01:16:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 110
Mileage: 64902 km
Date: 2055.14.23
Time: 01:16:46
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 110
Mileage: 64902 km
Date: 2055.14.23
Time: 01:16:46
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 110
Mileage: 64902 km
Date: 2055.14.23
Time: 01:16:46
Coding: 170B00
Serial number:
Coding: 000000
Coding: 0016437
Revision: 00H17000
Coding: 0016436
Coding: 0500040004
any ideas? (i think it has something to do with coding the new module to the car )...
please help Thanks :)
salsajoe
In: Salsa Red
Re: steering wheel module swap , epc light
Post by salsajoe »
What did you add to the controls that you needed to change the module? Looks like it might be incorrect programming as all faults relate to the steering sensors/controls and central electrics controller. Could possibly be an incorrect module? Module part numbers are a nightmare to get right. Another possibility is the slip ring controller was refitted incorrectly. This can cause steering control errors of the type you have listed.
You may find the list of output tests useful for the central electrics and steering wheel controllers http://www.sciroccocentral.co.uk/forum/ ... 36&t=10868" onclick="window.open(this.href);return false;
MTR11
Post by MTR11 »
i got airbag light in the old slip ring so i needed to change it ..
after tweeking some things in vcds i managed to ovecome the epc light problem by disabling the crusie control (i don't have CC fitted in my car ).. so now everthing looks good , no lights :)
