Hello i have a problem with my trunk relasse
I can not open my trunk by remote controller or button from my door side
I have changed my long code and can not remember the original codes
My long codes is here
A890000A88D37E470005840D60088A0BE03C00
Pls help
trunk problem
- uklee
- I drive a: GTS TDI
Re: trunk problem
How old is your car ?
Which controller have you been messing with ?
What changes were you making / hoping to make ?
Have you only had this problem since making these changes to the controller?
From my phone
From my phone
Re: trunk problem
Hi
It is from 2009
controller 46 is changes but i was also in 52 and 42 too
Now I have also problem with my passanger mirror, it is now will scroll down when i will reverse
It is from 2009
Re: trunk problem
That's not a problem that's designed so you can see the position of the rear wheel when you're reversing. Move the mirror control away from L (on RHD), presumably R (on LHD), and it will stop happening.Kangal wrote:Now I have also problem with my passanger mirror, it is now will scroll down when i will reverse
Re: trunk problem
...or uncheck "mirror dip" within the convenience menu within the MFD settingschelspeed wrote:That's not a problem that's designed so you can see the position of the rear wheel when you're reversing. Move the mirror control away from L (on RHD), presumably R (on LHD), and it will stop happening.Kangal wrote:Now I have also problem with my passanger mirror, it is now will scroll down when i will reverse
