Hello. Need some help with removing this cannister to make room for a oil catch can.
Is it safe to do it the way i drawn it in the picture? Remove the canister and the small hose and connect the bigger hose where the smaller hose was in the white "nipple". Theoretically it should work the same but bypassing the cannister.
Thanks.
Charcoal canister delete
