Hi, I have a Scirocco R which I have had 10 months now from brand new. My car was one of the last Sciroccos built. I am extremly happy with it.
I do have question that I hope somebody might be able to help me with. The DRL on my Scirocco are within the headlights and not on the bumper. Those lights lower down within the bumper are the indicators on my car. As far as I know I cannot turn them on as DRLs as well. I certainly can't find out how to do it on the instrument panel.
Does anyone know whether or not they turn on? and if not, how can I get them to run as DRL in addition to the built DRL I currently have?
I may not have worded this well, so hope you can make sense of what I saying.
Please see photos below.
IMG_6095 by Jonathan Freeman, on Flickr
IMG_6096 by Jonathan Freeman, on Flickr
Question about DRLs on the newer Mk3 Scirocco
- RoccoR
Re: Question about DRLs on the newer Mk3 Scirocco
I have seen a few R models with them on during daylight hours, have you checked this? i also have purchsed an 'r' style bodykit and mine work as both indicators and drls
- Deagol
Could you take a photo of your car from the front, whilst the DRLs are illuminated, so we can see exactly what you mean please? I thought that one of the easier visual differences between the R and a standard Scirocco was the position of the DRLs. My TDi for example uses "dipped headlights" as the DRL and every R I have seen on the road has the posher LEDs lower down in the front bumper.
Mind you, if VW were using up a stock of parts with the last few cars to leave the factory, goodness knows what you might have had built into the front end of your particular vehicle.
A picture may be worth a thousand words....
D
D
Baptised with Aerosmith
- RoccoR
Thank you mikejtaylor96 and Deagol for your replies.
I cannot find any way to switch them on as DRLs. Although they look clear from the front, they illuminate orange when they indicate. However, I cannot find any way at all to get them to illuminate as DRLs. Perhaps they are only indicators. Any further input much appreciated.
I’ve just called into my local VW dealership and the manager of parts and service has confirmed that they are indicator LEDs only and apparently £90 each.
I’m not sure whether there’s a retrofit kit out there is a indicator and also DRL. I’ll have to research it.
Cheers guys
Cheers guys
I’ve got an R and they only function as indicators, the DRLs are built into the headlights.
- RoccoR
Thanks 2207 and davidscirocco, for your reply’s. David the indicator lights don’t turn on with the headlights. I’ve tried everything and they only indicate
As 2207 said the DRLs are built into the headlights. It would have been great if VW allowed for the indicator lights to have a multifunction as both an indicator light and optional DRL if you want it switched on.
