2.0 Tsi Engine rattle
Keagan245
Options: All extra options
Post by Keagan245 »
Hey guys, I’ve got an issue with my 2011 roc, fuel consumption is ridiculous with a little white-blueish smoke on cold starts and when the car stands for a while. This happens seldomly though. When the engine is warmed up and I’m on the road the car drives relatively smoothly on the motorway however at idle while at traffic lights the car idles rough. I’ve got a downpipe and free flow induction system with stock software which I don’t believe has anything to do with what I’m experiencing. Oil and coolant levels remain constant with no signs of mixing and have put in iridium spark plugs as well as new coil packs with no change.
Replaced engine and gearbox mounts through VW as well as a new water pump if that’s of any relevance.
Here’s a video to how the car sounds currently
Any ideas on what could be the issue or issues :?
Zanic L3
Re: 2.0 Tsi Engine rattle
Post by Zanic L3 »
Maybe its the famous chain problem that is showing up? Search for chain tensioner and chain related stuff here on the forum and google it's known to be a problem on 2008/9-2012 models, how much mileage do u have?
Keagan245
Post by Keagan245 »
I’m currently on 105,000ks. I was told that the revised Chain was fitted but I don’t know at how many Km’s. How would I know if it’s maybe acting up again? Are there any symptoms?
Psycho Kirky
In: Salsa Red
Options: MODS-
K&N Typhoon Induction kit
BCS Powervalve custom sport TBE
REVO Stage 2 remap
Airtec Stage 2 Intercooler
Forge diverter/recirculation valve
Sachs Performance clutch
'Heavy Set' silicone hoses
REVO Torque Mount Insert
Various detailing
Post by Psycho Kirky »
The timing chain tensioner could be failing. Or the pcv valve perhaps. It may be worth going to.a highly trusted and independant VW specialist. Dealers don't always come out on top!
Sent from my SM-A320FL using Tapatalk
Zanic L3
Post by Zanic L3 »
Keagan245 wrote:I’m currently on 105,000ks. I was told that the revised Chain was fitted but I don’t know at how many Km’s. How would I know if it’s maybe acting up again? Are there any symptoms?
Ah then I don't know mate, gl fixing it though
