Hi all, does anyone know what the "Off" marking on the + flappy paddle does? I had this on my previous car as well & have no idea what it's supposed to turn off.
Cheers,
Bops
Sent from my BBB100-1 using Tapatalk
"Off" on flappy paddle
- I drive a: R-Line
Re: "Off" on flappy paddle
So let's say your in automatic drive mode and you want to overtake, you flick down on the downshift paddle and it puts it into manual mode for 30 seconds. If you want to go back to auto quicker than 30 seconds you can hold down the upshift for 2-3 seconds and it will go back into auto.
Ahh ... ok. Shall give that a try. I used to shift the gear selector across to manual & back to auto but this sounds a lot nicer.
Thanks for that
Thanks for that
- I drive a: R-Line
To be honest that's what I do , just stick it in manual , however if it's a spur of the moment over take (for whatever reason) then you can just flick the paddle down a gear or two.
Good to know I guess.
True. Good to have options ...
Re:
A quick search would have come up with the answer;
http://www.sciroccocentral.co.uk/forum/ ... le#p206367" onclick="window.open(this.href);return false;
Sent from my BBB100-1 using TapatalkCuprabob wrote:A quick search would have come up with the answer;
