Buying new parts
Buying new parts
When buying genuine VW Scirocco parts it would be a good idea to tell us the cost of said part. I will start with:
Inlet manifold £470 (vat already added)
2.0ltr tdi 2010.
2.0ltr tdi 2010.
Re: Buying new parts
scirocco 2.0 tsi 2010 just turned 101300 miles
inlet manifold genuine from usa inc postage £148
high pressure fuel pump £204
low pressure fuel pump £198
cam follower/fuel pump £35
coils £38 ea
timing chain tensioner £48
coils £38 ea
Rear shock absorber (DCC version) - £320 for part. Fully fitted by VW for £350 with 2 year warranty.
- Zanic L3
How much was the timing chain tensioner in labor? They have to take the engine out right?racetech wrote:scirocco 2.0 tsi 2010 just turned 101300 miles
- Roy_01
3D0 973 703 1 pc Waterproof connector alarm horn EUR 4,84
3B0 972 741A 3 pc Waterproof seals for alarm connector EUR 1,68
1E0 971 921 1 pc Cable protector elbow for alarm horn connector EUR 4,98
000 979 019E 2 pc Repair wire alarm connector EUR 10,38
000 979 225E 1 pc Repair wire fusebox EUR 5,19
N10 261 501 1 pc Small fuse 5 amp for position SC17 EUR 0,55
000 979 009E 6 pc Repair wire for bcm and interior sensor EUR 22,86
000 979 242E 1 pc Repair wire bcm EUR 7,13
8K0 973 754 1 pc Alarm deactivation switch connector EUR 1,55
8E0 971 832 1 pc Interior monitoring sensor connector EUR 3,29
1K8941717 1 pc facelift xenon breather hose L EUR 7,33
1K8941718 1 pc facelift xenon breather hose R EUR 4,43
1K8 823 729A 2 pc bonnet damping foam piece EUR 13,38
All prices total and ex.vat
nope engine stays in,, chains are all good,,,i did it myself,,aprox 4 hrs,,,,changed out oil and filter at the same timeZanic L3 wrote:How much was the timing chain tensioner in labor? They have to take the engine out right?racetech wrote:scirocco 2.0 tsi 2010 just turned 101300 miles
- Zanic L3
Ah rlly? I asked VW to check it when I replaced my inlet manifold a few weeks ago.. They told me that they had to take the whole engine out to check it, since I was already upto 800€+ for the inlet (including labor) I didn't push them to check tensioner but they did have a listen to it in when it's cold and told me they didn't hear anything strange, that the car wasn't misfiring etc. So hopefully everything is going well.racetech wrote:nope engine stays in,, chains are all good,,,i did it myself,,aprox 4 hrs,,,,changed out oil and filter at the same timeZanic L3 wrote:How much was the timing chain tensioner in labor? They have to take the engine out right?racetech wrote:scirocco 2.0 tsi 2010 just turned 101300 miles
When I asked them about the chain tensioner, they instantly knew what I was on about.
you have a 2.0tsi ?????,engine defo stays in,,not sure where you are located,,,,,,,mine had just started to have a strange rattle on start up,,ive owned the car 4 years and done 50,000 so I know all the noises it makes,,,did mine as a precaution really,,,measured the chains before tensioner removal and distance was all within specs,,,
- Zanic L3
Ye mate I have a 2.0, they also told me about it rattling on startup then it's def time to get it checked; what does the rattle sound like lolracetech wrote:you have a 2.0tsi ?????,engine defo stays in,,not sure where you are located,,,,,,,mine had just started to have a strange rattle on start up,,ive owned the car 4 years and done 50,000 so I know all the noises it makes,,,did mine as a precaution really,,,measured the chains before tensioner removal and distance was all within specs,,,
,,,a metallic rattling noise that wasnt there before if you have owned the car for a while you get used to the nioses it makes,,,,typically only rattles on a cold start,,,,when it does it warm or hot starting to its time to get it checked and replaced,Zanic L3 wrote:Ye mate I have a 2.0, they also told me about it rattling on startup then it's def time to get it checked; what does the rattle sound like lolracetech wrote:you have a 2.0tsi ?????,engine defo stays in,,not sure where you are located,,,,,,,mine had just started to have a strange rattle on start up,,ive owned the car 4 years and done 50,000 so I know all the noises it makes,,,did mine as a precaution really,,,measured the chains before tensioner removal and distance was all within specs,,,
