what wires go where? heated seats.
Postby Mr ade » Sat Feb 20, 2016 12:04 pm
Hi all, I have recently fitted the heated leather seats and the climate control panel with the seat switches. I have been to my local vw dealers to try and get the wires to connect them up but this is easier said than done...they don't seem to know any part numbers for the bits of loom I need?...so I got to thinking why don't I just get some wire and do it myself?...can someone give a definite answer to where the wires go...
Passenger side...
White goes to central electric control module...
Brown goes to earth
Blue/white goes to...seat switch?
Red/yellow goes to....?
Red/black goes to ....drivers seat?
Blue/purple goes to. ..drivers seat?
Blue/yellow goes to... drivers seat?
Drivers side...
Brown goes to earth
Blue/purple links to passenger seat?
Blue/yellow links to passenger seat?
Red/black links to passenger seat?
Any ideas anyone?
Most scirocco's are all the same but some are different...
Mr ade
Options: Pan roof, sat nav, Bluetooth, heated leather, park distance control, tpms, big speedo, cornering lights, sil covers, chrome exhaust tips, white lower front grille, gold coloured calipers,
Re: what wires go where? heated seats.
Postby glenn85774 » Mon Feb 22, 2016 6:21 pm
Did you buy replacement leather seats?
glenn85774
Postby Roy_01 » Mon Feb 22, 2016 7:05 pm
I don't know the wireing but here you can download all the needed diagrams for £5/hour. Wich you can save on your pc.
https://erwin.volkswagen.de/erwin/showHome.do
|Direct TPMS|Gen3 clima|Polar FIS PF03|Bearlock|Staging color mfd|RV-cam|Heated seats|Lane/Side/Fautigue/Front/HB-assist|Dyn+stat.cornering xenon|Facelift front|Seatdrawers|Door warning/handle/ambient LED|Alarm|BMC CRF797|Wagner IC|Adaptive cruise|
Roy_01
In: Sumatra
Options: |Keyfob fold mirrors|pano roof|18"detroit|remap 225 hp 435 Nm|DSG remap new shiftpoints|Bonnet mono-strut|Washer fluid level sensor|DSG paddle extensions|Usb dock|Dectane KV41KLRSY|EGR disabled|Kenwood DNX525|Calearo DAB+|CC|Vcds mods|R32 brakes|Eibach B12 Pro Kit|GT1749VC|
Postby Mr ade » Mon Feb 22, 2016 8:49 pm
I've gone one better...I've managed to get a complete interior loom!...I've done lots of searching on this and no one seems to have the answer so I will do a detailed how to as to where all the wires go when it turns up and I get the time . I have changed the non heated cloth trim to the OE heated leather so far and also changed the climate control unit to one with the heated seat switches (which I paid £40 delivered).
Mr ade
Postby adam8enson » Thu Mar 03, 2016 10:25 pm
I've just bought OEM leather seats (heated and electric lumbar) with plans to hopefully do exactly what you're doing, my current seats are cloth unheated. I've spoken to a few people and they say it's next to impossible to retrofit the seat heating wiring and I'll just have to leave them unheated, if you could keep us posted on progress that'd be brilliant!
adam8enson
Postby Mr ade » Fri Mar 04, 2016 11:52 am
I've got a complete interior loom from a 13 plate tdi r line. Tomorrow I'm going to unpick the wires I need and update my findings on here.
Mr ade
Postby Mr ade » Sat Mar 05, 2016 5:58 pm
ok, so I finally had the time to do the wiring on my seats...first I opened the box....
and unravelled the mess...
I located the plugs that I needed and started to unpick the tape...I do not recommend this as it is a bugger to do...there is no way you would get these wires out of a scrap car.. the only way is if the loom is in front of you.
after a couple of hours I ended up with this...
on the passenger seat there are 7 wires coloured as follows...
thick brown... this is an earth.
red and yellow...this goes to the fuse box...fuse number 37 which should be a 30 amp.
red and black...this joins up with the red and black on the drivers seat and then both go to the fuse box...fuse number 34 which should be a 15 amp.
blue and purple...this wire goes to the drivers seat and joins to the blue and purple on the seat connector.
white...this goes to the central electric control module..if you remove the lower dash panel on the drivers side and look above the accelerator pedal, you wil see 3 big plugs. 1 is black, 1 is white with a black locking clip and the other is white with a sandy coloured locking clip. you need the white with the black clip which looks like this...
I you look at the end where the wires go in, there are 2 tabs which, when moved, hold in the inner part of the plug...
this inner part then slides apart...
the white wire goes into the 4th small hole from the end...
there are 2 remaining wires , blue/yellow and a blue/white. The blue/yellow joins to the blue/yellow on the drivers seat then, along with the blue/white, go to the climate control unit in the dash... on the back of this there are 3 plugs marked A,B and C. you need plug A which looks like this...
the next picture shows the position of these 2 wires when fitted, blue/white to the outside and blue/yellow to the inner...
the only problem I can foresee if you are making your own loom is the connectors... the blue/white and blue/yellow for example...
the white wire also has this connector on the end...maybe maplins or the like sell these??....the connectors on the seats can just be cut off and each wire can be fitted with spade or bullet connectors.
The 4 wires from the drivers seat should be connected as follows...
thick brown...this is an earth.
blue/purple...should be joined to the blue/purple coming from the passenger side seat.
black/red...this should be joined to the black/red coming from the passenger seat then both go to fuse number 34 on the fuse box.
blue/yellow...this joins to the blue/yellow that comes from the passenger seat and then goes to the climate control unit in the dash.
all that is left to do is connect up to vcds...go to central electrics and find 'seat heating enabled'...check the box and hey presto...warm arse!!!
this was all done on a 61 plate (2011) scirocco gt tdi blue tech so if any wires are different then ??????? and if your car sets on fire its not my fault.. :shrug:
also, if the remaining loom is of any use to anyone, its in the for sale section for any reasonable offer.
hope this helps.
Mr ade
Postby wensleydale » Sun Mar 06, 2016 2:45 pm
Those connectors look like VW PN: N 907 647 01 and are also available as repair wire PN: 000 979 009
wensleydale
Postby Cuprabob » Sun Mar 06, 2016 2:50 pm
Excellent work...I feel a little guilty for not using my heated seats now:-)
Postby Roy_01 » Sun Dec 04, 2016 5:07 pm
Does anyone know if the golf mk6 heated seats loom can be used on the MY10 Scirocco?
http://www.kufatec.nl/shop/en/volkswage ... golf-vi-62
Roy_01
In: Sumatra
Postby Roy_01 » Sun Dec 11, 2016 3:15 pm
I have bought the Golf VI loom for heated seats only (seat and backrest), without lumbar heating for a LH drive.The loom is just universal with other VW models.
Downloaded all the electric diagrams.
So next step is to install the loom and seats.
Wiring diagram for 2010 MY.
Driver:
Pin 1: white ---> To CCM connector B pin 21
Pin 2: blue/white ---> To climatronic T20C pin 10
Pin 3: Red/yellow ---> To fuse 37 (30A)
Pin 4: Blue/yellow ---> To climatronic T20C pin 11
Pin 5: Brown ---> To ground point
Pin 10: purple/blue ---> To pin 10 passenger seat
Passenger:
Pin 10: purple/blue ---> To pin 10 driver seat
Edit: The golf VI loom to the passenger seat was not long enough for me and have to be extended a bit. (20-30 cm)
But there are only 3 wires on this side for a LHD so not that difficult. There were also 2 wire ends in the loom i didn't need, i measured them and they were electrical connected so 1 wire.
Roy_01
In: Sumatra
Postby Roy_01 » Mon Jan 02, 2017 2:42 pm
Today i connected the last wires of the seat heating loom:
- Added a new 30A fuse (37) in the fusebox and made the connection
- 1 wire to the bcm
- 2 wires to the climatronic panel
- 2 wires to the ground point on a-pillar left
Coded the memory function of the seat heating level in the adaptation channel of the climatronic with vcds. And checked the bit in module 09 heated seats installed.
Now enjoying my hot ass :) . Next project is the facelift xenon with afs (dynamic cornering lights)
Roy_01
In: Sumatra
Postby willid80 » Tue Dec 12, 2017 9:04 pm
This looks a bit daunting. How difficult is it to just get the electric lumbar support working?
willid80
Options: Leather Seats, Parking Sensors
Postby Roy_01 » Wed Dec 13, 2017 4:22 am
Almost the same amount of work, it uses the same harness + some adittional wiring.
Roy_01
In: Sumatra
Postby Moschops » Wed Jan 10, 2018 7:46 pm
Omg was going to try this until realised the amount of work. I presume can get someone to do this but what sort of cost would it be approx ?
Moschops
In: Oryx White
Postby Roy_01 » Wed Jan 10, 2018 9:06 pm
The loom is 50 euro and around 6 hours work.
Roy_01
In: Sumatra
Return to General Scirocco Talk
Who is online
Users browsing this forum: No registered users and 46 guests
