Candy White KW V1s and a few other bits.....
Thought I would start one of these build threads off. Its a 2.0tdi 170 dsg 11 plate with full leather, sat nav and a few other extras. Bought it in Leeds and drove it back to Sunderland. Couldn't of been happier with it.
The car when I picked it up.
I bought it in january and straight away got sick of seeing exactly the same standard cars passing me so first of all I dropped it off at the local paint shop and had the front lower grill painted white, gloss black mirrors and the small lip on the back bumper done gloss black.
I also changed all the bulbs out for brighter white ones and leds for the interior due to how yellow the original bulbs were.
Ive used my iphone to take the pictures so thats why they are crap quality and this photo I've used off a forum but cant remember where i got it from but its exactly the same set up.
Thats as far as Ive got for now, future plans are:
H&R ultralow coilovers (drops 50 to 80mm)
19's, not sure what to go for, maybe 3SDM 0.05s when there released later this year.
scirocco and 2.0tdi badge removal
VW badges gloss black
a few recent pictures...
I was after some H&R ultralow coilovers but with mine being a fatty diesel/ dsg it was too heavy .So I decided to go for some KW V1s instead. I got a good price from Revolution in gateshead so got them bought fitted and aligned there. Sorry for the cack pictures only got it done this afternoon so iphone special again!
looks like its on stilts to this...
the rear is all the way down and the front has 20mm ish to go. left the front slightly higher to try out speedbumps to work and no problems so going to drop it a bit more when I get the chance. Looks loads better in the flesh! badges are getting done gloss black next week. Now what wheels to choose????
Re: Candy White KW V1s and a few other bits.....
the car looks great, i like the lip gloss black paint you got on the rear bumper. very clever, not feeling the front grill in white though. not my sort of thing but each to their own,
cheers, the black breaks the car up and just adds a bit more to it, all white its too plain for me.
i'd even out the ride height as for me just a tad low at rear, critical dimension for me was clearance to front jacking point (i had 85mm) as this caught on some plastic bumps, also plastic under tray, just lower my golf which looks lower than the roc but has 25mm more at jacking point
the rear is at its lowest mate. should settle a little lower, I've got 20mm left in the front. What coils did you have on?
Gaz whats your camera setup for the arty interior shots above? Car is looking good by the way, i need to get some Kw V1's in my life, are you running the DDC delete kit or the compliant one?
It was a while a go when i did it. I had it in auto I think as I just got the camera, theres a setting that allows you to pick one colour and leave the rest B&W but you can just do the same effects using photoshop. I just got the delete kit, got the ddc cables covered up in electricians tape and tie rapped up out the way. Theres no point in paying an extra 200 for the compliant one when you can either pull the dcc switch out and disconnect the bulb. Or you can remove the fuse for the suspension and it stops the light from flashing so just like normal. I havnt done either yet but will probably pull the fuse out.SC60_CCO wrote:Gaz whats your camera setup for the arty interior shots above? Car is looking good by the way, i need to get some Kw V1's in my life, are you running the DDC delete kit or the compliant one?
Fair one mate, mines on the 35mm H&R springs and has been for the last year or so, ive never really been happy with the ride height even with them on. Ive been quoted over a grand for the V1's with the plug in to stop the button flashing and over two grand for the ones that switch the damping using the original dcc switch. Seems like an obvious choice, V1s, some electrical tape and cable ties it is!
Just a little update that might help some of you that are getting or thinking about getting coilovers. To stop the light flashing< I simply pulled out the ddc fuse located on the side of the driver side dash.
Simply use a flat headed screwdriver to remove the cover. on the rear of the panel there should be a tweezer like object to use to remove the fuse. finally look in your car manual to locate the correct fuse. my manual didnt have a diagram or any information on it. But in my mates 09 2.0tsi gt there was one and guessed it would be the same one, we tried it and it worked. The button does not flash anymore and just stays off. A 5 minute job instead of removing the bulb from the button. Took it out for a spin and the handling doesnt feel any different to what it did in sport.
Are you sure you want to do that!
The steering, brakes & engine controllers may be comprised by lack of data on the CAN bus network. And in the case of DSG fitted, that controller as well.
Cancel modules is the way.
Hmmm... may have to put it back in and think of something else. no way am I paying 200 for cancel modules. May just stick some vinyl over the button so I cant see it flashing.RW1 wrote:Are you sure you want to do that!
Wouldn't be surpirsed if you now have a few fault codes in the diagnostics memory
I just unplugged the switch at that end rather than pulling any fuses. Not sure if that is any better, I've never had any errors or problems in 8 months though.
Car looks great by the way!
Cheers bud, put the fuse back in, just got some black vinyl for bottom layer and some grey to go over the top. That should stop any light coming through. Not perfect but it will do for now. Just puts a big smile on my face everytime I walk towards it now. Still alright over speed bumps as well if I take it easy. The girlfriend thinks the rides to hard and it looks ridiculous so it must be good
First time I took mine to show my old man he thought it was rediculous, but now he says every time he sees another roc he can't believe how high they actually sit.
Im ok on most speed bumps with a 50mm drop. The only ones I have trouble with are those ones that are just a lump of tarmac in the middle of the road, I try to move over and use both or just have to put one side up and over. Normally end up with a queue of traffic behind me but oh well...
Haha bet you've been told its a waste of money as well! Yeah those are the worst, 5-10mph now instead of the usual 30. Or the ones that are straight up straight down. How are you in multi-stories??
Quick update, managed to get a hold of some rotiform blqs 19x8.5 et 45 with nearly new falken tyres for a very cheap price, no pictures as im on iphone. There a bit crazy with them being lime green! There running stretched tyres, 215 35 19, too stretched for me as I'm up and down curbs a lot so need a bit more protection. Doing a swap with someone for some 225 40s so should be better for me. Not sure how long I'll keep them lime green but I'll run them for a while. Pictures to follow later this week... Also locking wheel socket is too large to tighten on rotiforms so new locking bolts needed.
Spacers, black badges next on the list.
test fit
new wheels on and a few better pics, 19" rotiform blq in lime green. its a bit in your face but better than the usual black wheels on a white car. Running them like this for a while. maybe get them re-done white during the winter or buy something different. Thoughts and opinions? good or bad.
and one to show the silly ride height before and after
